Headliner Bow Pockets - 1970 'Cuda #1133962
12/14/11 01:54 PM
12/14/11 01:54 PM
Tucson, AZ
73ChargerSE Offline OP
Tucson, AZ
Hey Guys,
Working on a '70 'Cuda in the shop. Just wondering, does the last bow by the rear window have the headliner pockets? We have a total of 8 clips/pockets for the car, should we have 10? If so, does anyone have pictures of where they are supposed to go on that 5th bow? The bow seems to want to fit in the middle of the two slots in the inner structure.
Thanks!
Paul
Re: Headliner Bow Pockets - 1970 'Cuda [Re: 73ChargerSE] #1133963
12/14/11 06:50 PM
12/14/11 06:50 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
There are 10 clips for the 1970. Do you have the upper and lower toothed, sheet metal strips installed? If memory serves, it hooks onto the top one. If you look closely in the pic, you can see a slight discoloration on the upper strip where the clip goes.
Re: Headliner Bow Pockets - 1970 'Cuda [Re: jbc426] #1133964
12/14/11 06:51 PM
12/14/11 06:51 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
With headliner installed.
Re: Headliner Bow Pockets - 1970 'Cuda [Re: jbc426] #1133965
12/14/11 08:21 PM
12/14/11 08:21 PM
Tucson, AZ
Tucson, AZ
Would anyone happen to have 2 clips? Need them ASAP.
Thanks!
Paul
Re: Headliner Bow Pockets - 1970 'Cuda [Re: 73ChargerSE] #1133966
12/15/11 09:44 AM
12/15/11 09:44 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
going off of memory but here goes
