Re: lower control arms [Re: 70sate] #1132563
12/16/11 03:46 AM
12/16/11 03:46 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
thanks men,the threded sterring arms on the 74 dart setup they sold me for $80 complete w/lca`s,had me confused.looking at the 70,b-body disc set i got the same day 4 my 70 satelite could see bolts going through the balljoint,did`nt know about the nuts on the roter side,thought it was the same on my satelite drum system, till i cleaned off the ball joint to see nuts on the ball joint side holding it on,the spindel match is good, using nuts+bolts from b-body drum conf.guess you can put bolts in front or back,i will put the nuts on the inside.
For $80 you did fine.
Re: lower control arms [Re: autoxcuda] #1132564
12/16/11 12:13 PM
12/16/11 12:13 PM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
You can not put the nuts on the rotor side the rotor will hit the nuts.
