correct finish on a few parts for 69 #1132276
12/12/11 09:11 AM
12/12/11 09:11 AM
DFW
68RRFlyer Offline OP
DFW
Mornin' Gents. I'm having a friendly discussion with some other mopar peeps about correct finishes on a few parts and I'd like some more input:
Leaf Springs: For 69, I know they were painted black. But was the whole spring painted after it was assembled as a unit? In other words, the clamps and insulators get blacked out as well?
Valance brackets: The brackets on the back of 68-70 Chargers that bolt to the rear frame and pass under the valance and provide a mounting point for the rear bumperettes. Are these natural steel or painted black? All the ones I've ever seen off original cars had no traces of any black paint on them. But I know the factory paint was applied pretty thin, so it just may have worn off over time. So black or natural colored?
Pinion Snubber: Black or natural? 8.75", not the Dana. I now the 3rd member was natural, just didn't know if the snubber was black or natural.
Brake Backing Plates (F & R): Black or natural? I have seen both. What's considered correct? I have found several markings on front backing plates (all 11") and have yet to find any remnants of black paint. This includes St. Louis and Hamtramck cars.
Upper Control Arms: Black or Natural?
I know there were differences from plant to plant and it's not an exact science, but from what I've asked what is acceptable on judging? Is there a plating/finish guide out there somewhere? I have one that's pretty old, and it jumps around so much it's hard to follow so I want to make sure I'm understanding what they say correctly. Thanks!
Cheers
Re: correct finish on a few parts for 69 [Re: 68RRFlyer] #1132277
12/12/11 09:47 AM
12/12/11 09:47 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Sorry - honestly I'm not confident enough to answer this one
but -
Valance brackets: natural
Pinion Snubber: natural
Brake Backing Plates (F & R): black( dark ) phosphate - not painted
Upper Control Arms: Black or Natural - personally I've seen them both ways
Re: correct finish on a few parts for 69 [Re: 68RRFlyer] #1132278
12/12/11 10:59 AM
12/12/11 10:59 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Most typical springs were natural. Only a few from certain factories were painted in 69 B-bodies. If painted they were brush painted flat black.
Drum brake backing plates - Zinc phosphate plated
Upper Control arms - Typically flat black. 40% flattened acrylic enamel.
Per Roger Gibson retoration article.Mopar Action Dec. 1993
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: correct finish on a few parts for 69 [Re: MOPARMIKE69] #1132279
12/12/11 12:12 PM
12/12/11 12:12 PM
DFW
DFW
What say you on the springs Jim? Yours is the article I'm using as my reference and by hard to read, I just mean my scans are bad. With regards to A12 cars, the springs were black. But again, different plants than Chargers. Is it plant specific or were all 69s painted? By the way, thanks for the corroboration on my 70 Charger skid plate issue on the other board.
Update: Just reread a question I asked on the A12 forum and saw your reply there. So looks like really, any finish is correct depending on what supplier/vendor was used.
Cheers
Re: correct finish on a few parts for 69 [Re: 68RRFlyer] #1132280
12/12/11 12:28 PM
12/12/11 12:28 PM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
Paul Jacobs did my 69 RR. A couple of pictures are attached.
Re: correct finish on a few parts for 69 [Re: Mopar Grandpa] #1132281
12/12/11 12:29 PM
12/12/11 12:29 PM
Sebring, Florida
Sebring, Florida
Front
Re: correct finish on a few parts for 69 [Re: 68RRFlyer] #1132282
12/12/11 12:40 PM
12/12/11 12:40 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Cheers
Pic of an original survivor A12 bee. Natural springs
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: correct finish on a few parts for 69 [Re: 68RRFlyer] #1132283
12/12/11 12:55 PM
12/12/11 12:55 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
...Leaf Springs: For 69, I know they were painted black. But was the whole spring painted after it was assembled as a unit? In other words, the clamps and insulators get blacked out as well?
Dave, this is what I have seen from Geno's thread. I don't think there are many people on this planet that has done as much research in to OEM correct on a '69 Charger as Geno.
Geno's Daytona restoration thread on the Charger Board. << Click here
The leaf springs were painted black...
backing plates: Going by Geno's for '69, natural..
upper control arms. Look natural with cosmoline for corrosion control.
rear bracket tip plates: natural.
backing plates: natural
Troy
Houston Mopar Connection Club
Re: correct finish on a few parts for 69 [Re: hemi68charger] #1132284
12/12/11 01:04 PM
12/12/11 01:04 PM
DFW
DFW
Just posted an update further up. I asked this question on the A12 board and Jim replied there. Looks like it depends on the vendors that supplied the parts as to the finishes, particularly the rear springs is what I'm referring to. Further evidence in this thread alone shows one car with painted springs and one with natural. I guess it's just a matter of detective work to find out what originally came on your car to begin with and replicate as necessary.
Mopar cars are a bit like golf. Consistently inconsistent. Fun stuff!!! Thanks for the answers on the other items gents!
Cheers
Re: correct finish on a few parts for 69 [Re: 68RRFlyer] #1132285
12/12/11 01:43 PM
12/12/11 01:43 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
If you take the springs apart, you will find that they look like they were painted black. In reality, I do not believe they are painted. You cannot scratch or use paint remover to get the black off. They are black because of the tempering process of heating them and cooling them. The clamps are also natural and not painted as far as I know? Replacement springs on the other hand seem to be completely painted to keep them from developing surface rust on the shelf or in storage. The 69 and earlier B-Body springs definitely do not look silver or light steel looking. They are blackened. Now the shock mounting plates, that's a separate question?
Re: correct finish on a few parts for 69 [Re: RoadRunnerJD] #1132286
12/12/11 02:34 PM
12/12/11 02:34 PM
SE Pa.
LimeliteAero Offline
SE Pa.
ive never seen the shock plates anything but natural.
