Re: Big Block Crane Gold rockers and roller cams
[Re: moparmanjames]
#1131810
12/11/11 06:09 PM
12/11/11 06:09 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
They dont seem to be popular with the Mopar crowd, probably for a reason... Chevy guys run them all the time. You really didnt say much about the cam, other than .700 lift. Is this a solid flat tappet with moderate 3025-350pen pressure? Or a solid or hyd roller with 500+ lbs of open pressure? Big diff between the two. I assume its a roller of sorts, cause there isnt too many .700 lift fat tappets, although I had a custom Bullet racing cam from Ray Barton for a Hemi I built. I would avoid the higher spring pressures that are required with a roller cam utilizing those rocker arms. I still like and recommend the Isky/Crane Ductile rocker arms for mild flat tappet cams for adjustable valve train. They just last for years and years. If you have a roller, I consider the Harland Sharp rockers for a entry level engine with moderate spring pressures.. One thing I have learned over the years is, there is places to skimp, or save money on a performance engine, but the valve train isnt one of them. ![](/ubbthreads/images/graemlins/Twocents.gif)
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#1131811
12/11/11 07:32 PM
12/11/11 07:32 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
It's a solid roller with .705" lift with the 1.6's, I've already decided I need to buy some 1.6 Harland sharps. I bought these Cranes a while back and wanted some extra lift but I don't think I'll chance it. Thanks for the input.
[Re: moparmanjames]
#1131812
12/12/11 12:46 AM
12/12/11 12:46 AM
Posts: 43,332 Bend,OR USA
Cab_Burge
My Harland Sharps. both sets, 1.5 and 1.6 , check out at the retainer to be more ratio than advertised My 1.5, a very old set, are actually 1.54 at the retainers and the 1.6 are also 1.65 at the retainers Check yours first with checking springs before setting the valve springs up ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Cab_Burge]
#1131814
12/12/11 11:11 AM
12/12/11 11:11 AM
moparmanjames
Las Vegas NV
Thanks, will do. ![](/ubbthreads/images/graemlins/thumbs.gif)
