Ram 1500 backfiring through throttle body
#1131688
12/11/11 01:15 PM
12/11/11 01:15 PM
Posts: 710 Harrisburg Pa. 17112
moparmikethree
Neighbors 99 Ram 1500 with a 5.9 backfires through the throttle body.
I think he said while on the throttle and then leaving off
Re: Ram 1500 backfiring through throttle body
[Re: joedust451]
#1131692
12/12/11 10:33 AM
12/12/11 10:33 AM
Posts: 15,487 Florida
scratchnfotraction
Like scatch said, worn lobe, bent pushrod, broken rocker.
first off I would pull VC to see if all rockers are moveing about the same.
then run a comp test
[Re: scratchnfotraction]
#1131693
12/12/11 12:27 PM
12/12/11 12:27 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
hmm...what about an intake manifold plenum gasket leak causing an overly lean mixture coupled with sucking in oil?
[Re: patrick]
#1131694
12/12/11 12:30 PM
12/12/11 12:30 PM
scratchnfotraction
I thought of that too,my sons has a leaking intake and it wont pop back up thru thru the throttle body. does run like poop and blows a lot of smoke though it would have to go real lean..no?
[Re: buildanother]
#1131698
12/12/11 10:04 PM
12/12/11 10:04 PM
Posts: 28 Mississippi
bcr
Mississippi
I'd start with new mopar(champion)- plugs-wires-cap and rotor.
This If it does it while in a pull, like starting off or on a hill.
