Low buck upgrades? #1131603
12/11/11 11:26 AM
12/11/11 11:26 AM
tboomer Online work OP
tboomer  Online Work OP
Kinda thinking again...Dangerous,isn't it? Planning on glass bumpers from Sled City for my 64..Also homemade aluminum bumper brackets..Weight loss should equal a better e.t...Also want to get a quality coil and cap from Gorski to replace the autozone cap and Accel coil...I don't think that will hurt any. The MP electronic dizzy seems to work just fine. No sense replacing that! I like the air pan thread,but I don't think I have enough room under the hood!! Hope some of this stuff helps me...Anyone else have some good tips? Ted
Re: Low buck upgrades? [Re: tboomer] #1131604
12/11/11 12:28 PM
12/11/11 12:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The air pan would help with just the cooler air...
there is always a way... BUT I dont like the drop
pans, it makes too many turns for the air... lets
face it... air like to travel in a straight line.
Also if you put a bunch of stickers/decals on the car
you can pick up at least a 100 hp... if you believe
what each product can produce
Re: Low buck upgrades? [Re: MR_P_BODY] #1131605
12/11/11 12:36 PM
12/11/11 12:36 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I picked up an honest 25.45 HP with my decals Ted
PM me if you want some
Re: Low buck upgrades? [Re: roadhazard] #1131606
12/11/11 12:40 PM
12/11/11 12:40 PM
Thanks,Raff! Greg...When the time comes,we will need new valve seals and valve cover gaskets..I will let you know..
Re: Low buck upgrades? [Re: tboomer] #1131607
12/12/11 07:31 AM
12/12/11 07:31 AM
gregsdart Offline
gregsdart  Offline
Ted, how steady is the timing? Getting rid of any spark scatter may offer some Hp. Also on the air pan, I use a moroso dropped aircleaner base pop riveted to my airpan and sealed with silicon. Decided on that after working with a 383 that we tried a flat pan on, gained significant power with a better entry system. If you have a flush machined carb top (choke towers cut off)there is a cast piece that can be mounted to round out the air entry, forget who makes them.
Have you done a full graph on the front end for Bump steer? Needs to be with in 1/8 total top to bottom. Rear axle alignment? To be sure the rears are parallel. How are the brakes? Nice and lose?
Re: Low buck upgrades? [Re: gregsdart] #1131608
12/12/11 09:22 AM
12/12/11 09:22 AM
Greg...Good idea on the timing. Something to check into. I have a Dominator on it so no choke tower. There is probably only about an inch of clearance between the top of the carb and the hood scoop. I will not change the scoop!! It just looks too good on the car! I don't think there is any brake drag but it is something to look at. I do have a graph somewhere,I will look at it! Thanks!!
Re: Low buck upgrades? [Re: tboomer] #1131609
12/12/11 11:26 AM
12/12/11 11:26 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Ted I'm not sure what intake manifold you are using but you may want to do so research on it. I was really shocked after flowing a couple on the bench this year to find out how restrictive some are. I ported a set of chevy dart platinum heads this summer and when we bolted his intake on our numbers dropped from 308cfm-268cfm. After some intake work we were at 300. After seeing that I checked my small block super victor and W2 victor. I will never bolt another intake on an engine out of the box again. The best way to have it checked is with it bolted to your heads, and ask for before and after numbers. Post your head and intake combo and maybe one of our members checked one out.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Low buck upgrades? [Re: tboomer] #1131610
12/12/11 11:29 AM
12/12/11 11:29 AM
gregsdart Offline
gregsdart  Offline
On the aircleaner lid, mine is a dropped base, so the flat pan that is attached is lower than the carb aircleaner flange. If you want to do this, you can gain a 1/2 inch of clearance by making up spacers to go between the K frame and the frame rails. I used some half inch aluminum plate, cut them roughly 2 inch square, drilled the 3/4 hole for the bolt and wulla! The motor got lower by 1/2 inch. this whole setup would be better than only having an inch clearance.
Considering how tight things are now, there might be some good gains there. Carbs just don't like to be crowded up top.
Re: Low buck upgrades? [Re: tboomer] #1131611
12/12/11 11:48 AM
12/12/11 11:48 AM
Az
Crizila Offline
Crizila  Offline
Az
The best tip you will get on this thread is to fix the 1" scoop to carb inlet problem. Even going with a dropped base won't fix it. If you don't want to change the scoop, change manifolds or drop the motor some.
Fastest 300
Re: Low buck upgrades? [Re: Crizila] #1131612
12/12/11 12:00 PM
12/12/11 12:00 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
A good synthetic gear lube,and synthetic wheel bearing grease can help reduce some drag,which always helps. Plus I believe it helps with consitency which is a bounus to us bracket racers.
Keith
Re: Low buck upgrades? [Re: MR_P_BODY] #1131613
12/13/11 07:03 PM
12/13/11 07:03 PM
gregsdart Offline
gregsdart  Offline
One more thing you can try. If you believe you are still too tight hood scoop to carb, then loosen the hood hinges and raise the back of the hood as far as you can and see (reseal the airpan!) if it helps.
Re: Low buck upgrades? [Re: tboomer] #1131614
12/13/11 08:52 PM
12/13/11 08:52 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Snow Performance Meth/Water injection. $250 converts 93 into 114.
http://www.snowperformance.net/
I can tell when mines on for sure. Buddy claims a 427 3x2 veet picked up almost 60hp on the dyno.
Here's the Hemi chart.
Coming soon!!!!
Re: Low buck upgrades? [Re: Mr.Yuck] #1131615
12/13/11 10:11 PM
12/13/11 10:11 PM
Thanks for the ideas,guys! I haven't been around much,trying to fill the freezer! Raff knows what I mean... I do have a Victor intake that has been hogged out a bit...If I could knock off .2 working with what I have,I would be estatic!! Keep the ideas coming....I am all ears!!
Re: Low buck upgrades? [Re: tboomer] #1131616
12/14/11 03:59 PM
12/14/11 03:59 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
hi Ted
Dwayne recommended the super sucker spacer or adaptor for my motor.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Low buck upgrades? [Re: deaks] #1131617
12/14/11 04:34 PM
12/14/11 04:34 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Hey Ted
The thing i did that had the most surprising effect on ET( ALMOST A FULL TENTH) was going from a stock style water pump to an electric unit. My brother made this same swap right before i did with the same result.Helps between rounds at the track as well. REAL good upgrade that definately is seen on an ET slip.In conjunction with electric fan over a stock unit, you will see even a hair more if you still have a stock fan setup.
Doubt the bumpers and brackets will net much if anything.Been there done that.
Race front brakes didnt see on Et slip, going to fiberglass bumpers, didnt see on ET slip, big dollar fuel pump upgrade, didnt see on ET slip, lighter driveshaft, didnt see on ET slip, aluminum drum and roller bearings in transmission, didnt see on ET slip ...electric water pump, saw immediately and dramatically on ET slip.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Low buck upgrades? [Re: B3422W5] #1131618
12/14/11 05:41 PM
12/14/11 05:41 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Ted do you use an alt ? If you do you could put a switch in the field circuit and turn it off making a pass. Might get a half a tenth. Ron
Re: Low buck upgrades? [Re: 383man] #1131619
12/14/11 07:32 PM
12/14/11 07:32 PM
Az
Crizila Offline
Crizila  Offline
Az
Not a good idea with late ignition systems. Early point stuff would do ok on 12 volts. New electronic stuff likes 14 volts.
Fastest 300
Re: Low buck upgrades? [Re: B3422W5] #1131620
12/15/11 01:38 AM
12/15/11 01:38 AM
Az
Crizila Offline
Crizila  Offline
Az
Hey Ted
There can be a down side to some of these mods. Had a race last month in threatening weather. We normally have 30 minutes between rounds. It looked like rain was on the way, so the track steward was polling the drivers lined up for the first round to see if anyone had objections to 15 minutes between rounds. The guy in front of me had a kitten! Claimed he couldn't get his car cooled down in that length of time cause he had to hook up his charger to run his electric pump and recharge his battery. He obviously didn't have enough pump or enough alternator to go more than one round without needing a 1/2 hour break to "replenish". He did have a fast car though - for one round . Point is: be careful not to sacrifice too much on the reliability side for an extra tenth or so.
Fastest 300
Re: Low buck upgrades? [Re: gregsdart] #1131621
12/15/11 02:01 AM
12/15/11 02:01 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
How did that affect your alignment - not just the caster/camber, but also the bump stop heights, bumpsteer and turn in angles?
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Low buck upgrades? [Re: 383man] #1131622
12/15/11 02:24 AM
12/15/11 02:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Made 0 change in my ET
