Re: dana 60 with 40 spline axles and wilwood brakes
[Re: ALKYW5DART]
#1131465
12/11/11 03:38 AM
12/11/11 03:38 AM
Posts: 791 Bama
Randy..
Bama
True! the set 7 bearing is not big enough to accept the 40 spline axle, hence the need for a larger housing end and diff brake bracket.
[Re: ALKYW5DART]
#1131468
12/12/11 07:37 AM
12/12/11 07:37 AM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Do you really need the 40 spline axles? I run 35 spline in my Dart, 1.25 60 ft, trans brake, 3050 lbs. I do run the 5/8 studs, that to me is almost a must at my power level for safety.
