64-65 BB Bellhousing Questions ?
#1131392
12/10/11 10:24 PM
12/10/11 10:24 PM
Posts: 3,449 Gateway to the West.
hemi_harvester
OK..Will a 64-65 bellhousing work in a 66-up B-body car ? The reason I ask is a guess the bosses for the cross shaft might be in a different location.
also I have conflicting info on #2463019 Galen's book says it's 11" but other sources say its 10.5 is there any way to measure the housing to tell ?
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: 64-65 BB Bellhousing Questions ?
[Re: topside]
#1131395
12/11/11 02:40 PM
12/11/11 02:40 PM
Posts: 1,567 Ky
jt4406
Ky
I have a 65 bb bellhousing that I acquired in a trade. It does require the smaller cover (same as 70 513 aluminum bb bellhousing, but uses the smaller "small block" 4 speed bearing retainer, so if you have a 4 speed with the larger od on the bearing retainer it will not fit into the hole in the bellhousing, even though the 4 transmission bolt holes are the same. ![](/ubbthreads/images/graemlins/Twocents.gif) jess
Yeah, it's hopped up to over 160...
[Re: topside]
#1131398
12/11/11 09:20 PM
12/11/11 09:20 PM
Posts: 1,567 Ky
jt4406
Ky
P4529694 4-Speed Front Bearing Retainer- 4.35" O.D., 3.70" BC, for 23 Spline
P4529695 4-Speed Front Bearing Retainer- 4.80" O.D., 3.70" BC, for 23 Spline
P4529696 4-Speed Front Bearing Retainer- 4.80" O.D., 4.16" BC, for 23 Spline
P4529697 4-Speed Front Bearing Retainer- 4.80" O.D., 4.16" BC, for 18 Spline
