Page 2 of 3 1 2 3
Re: what does a 69 Dart with a big block weigh? [Re: dennismopar73] #1131269
12/11/11 06:50 PM
12/11/11 06:50 PM
Q
Quicktree Offline
Quicktree  Offline
Q
and that may very well be the case, but they are all not like that.
Re: what does a 69 Dart with a big block weigh? [Re: Quicktree] #1131270
12/11/11 07:00 PM
12/11/11 07:00 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
why? because they are not calibrated for accuracy down the 100s of pounds. try it some time smart guy
Makes me wonder as a year or so ago I took my duster down the road to a company that has a scale and at the time the car weighed 3260 without me in it. I thought that sounded about right. So last spring while Ryan had my engine I converted it over to wilwood and strange disc brakes and also put on streetlites and a cage. All told I probably should have at least lost 100 lbs even after adding the cage. So I took it to the scales a few months ago and what do you know it weighed exactly 3260 again?!? I had even lost 25-30 lbs and was definitely left scratching my head.
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: what does a 69 Dart with a big block weigh? [Re: Quicktree] #1131271
12/11/11 07:00 PM
12/11/11 07:00 PM
ill
dennismopar73 Offline
ill
SORRY FOR THE BAD LUCK ON YOUR SCALES,
scales can get knocked out, due to no maintance, weather, bad truck drivers, slamming brakes on it worse thing.
but if they are cert they have to be accurate +or- within # s not 100s of # why you say, because everyone get paid off scales in almost everything, including gas to cereal , if the scale is cert, and someone is cert it that way , he is not doing his job!
Re: what does a 69 Dart with a big block weigh? [Re: dennismopar73] #1131272
12/11/11 08:01 PM
12/11/11 08:01 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Holy crap! Mu simple question turned into a study of validity in scales!! awesome!
Anyway, this Dart I'm looking at has dana60 rear axle, that should make quicktree happy.
Mike
1969 Dodge Dart Swinger
Re: what does a 69 Dart with a big block weigh? [Re: MikeyT] #1131273
12/11/11 08:27 PM
12/11/11 08:27 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
My 68 with bb, aluminum heads, wp, etc..., 727, Dana 60, steelies, FULL interior, etc... weighs 3600.
codfish
Re: what does a 69 Dart with a big block weigh? [Re: codfish] #1131274
12/11/11 10:57 PM
12/11/11 10:57 PM
Eastern Shore of Maryland
N
nasty68 Offline
nasty68  Offline
N
My 68 all steel except hemi hood, 383, iron head, auto, full exhaust, no power anything, 8 3/4 rear with ladder bars, race buckets, with back seat and a 10pt cage is 3190 without me in it.
68 dart, 383, 727
2013 Jeep JKU Sahara
Re: what does a 69 Dart with a big block weigh? [Re: MikeyT] #1131275
12/11/11 11:12 PM
12/11/11 11:12 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Mike
Everybody here on Moparts is an expert on everything, even truck drivers.
If you want to learn more on scales check out Weightronix. If you
want to learn about 69 Darts then Moparts is the
place to get 1,000 different answers!
Snap your neck, mega G-force launch, is all I want!
Re: what does a 69 Dart with a big block weigh? [Re: codfish] #1131276
12/12/11 09:12 AM
12/12/11 09:12 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
codfish
I believe it. My '76 Dart is a fat turd too.
Re: what does a 69 Dart with a big block weigh? [Re: MikeyT] #1131277
12/12/11 09:24 AM
12/12/11 09:24 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
My 71 Demon is right at 3470.The car lost 60 lbs with aluminum heads,water pump/housing and radiator.
440/727/Dana 60.'Glass hood and 1 seat,no carpet 6 pt roll bar.the rest of the car is all steel.
And I will say that Quicktree is correct.On some scales here as I weighed my car/trailer at 2 different scales and the weights were different by over 100lbs.I don't know about OTR scales,I didn't use one of those.Next time I'm using the scale at the race track.
Nautilus Racing-
Re: what does a 69 Dart with a big block weigh? [Re: Chris2581] #1131278
12/12/11 09:28 AM
12/12/11 09:28 AM
tboomer Online work
tboomer  Online Work
I think 493 Darts 1970 came in around 3100? We weighed at the track and my beater came in at 3230..
Re: what does a 69 Dart with a big block weigh? [Re: tboomer] #1131279
12/12/11 09:54 AM
12/12/11 09:54 AM
ill
ill
Ok just scaled our 69 dart gts, bb, auto, 8 3/4 all factory, stock wheels, 2 truck scales ,and 1 portable came in at 3360, grain scales said 3380, truck scales on I55 said 3350
Re: what does a 69 Dart with a big block weigh? [Re: dennismopar73] #1131280
12/12/11 01:36 PM
12/12/11 01:36 PM
Q
Quicktree Offline
Quicktree  Offline
Q
now go to a division or national event race and weigh it and come back and report.
Re: what does a 69 Dart with a big block weigh? [Re: Quicktree] #1131281
12/12/11 08:07 PM
12/12/11 08:07 PM
ill
ill
We have weight it at Gateway ,RT 66,& Indy. Gateway was the heaviest
RT66 lightest, Indy same as truck scales on I55,
We also have a 68 bb dart gts, weights 100 lighter
So have enough scales time with the cars ,25-30# not enough for me to care about
carry on
Re: what does a 69 Dart with a big block weigh? [Re: dennismopar73] #1131282
12/20/11 01:29 PM
12/20/11 01:29 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
my 69 dart, all steel, steel police wheels with the fronts narrowed, 383, 727, and dana 60, full interior bench seat, headers 3" full exhaust, aluminum rad and intake, manual steering, 11" discs up front 11" drums on back. 3380 lbs on e-town scale.
Re: what does a 69 Dart with a big block weigh? [Re: JAMESDART] #1131283
12/20/11 02:22 PM
12/20/11 02:22 PM
Baltimore,MD
lowbudget Offline
mopar addict
lowbudget  Offline
mopar addict
Baltimore,MD
Yes, a Dart will be lighter. However, you will never replace the cool factor of the Coronet...just something to consider. I had a 69 Charger at one point and replaced it with my current 69 Dart and always kinda regreted it. Would the Dart always be faster cause of the weight advantage? sure. But the B bodys definately are more stylish (my opinion here) and you dont see them as often at the dragstrip. Especially ones that run quick
Re: what does a 69 Dart with a big block weigh? [Re: lowbudget] #1131284
12/21/11 11:51 AM
12/21/11 11:51 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I would take a 67-69 dart over any cornet...thats Just my opinion..
Re: what does a 69 Dart with a big block weigh? [Re: 70blackfish] #1131285
12/21/11 11:58 AM
12/21/11 11:58 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I have a 69 GTS but i think the 68-9 Coronets are sleeker than the Dart but not the others, personally, i like early E bodies the best and yours is the coolest on here Blackfish.
A body's are cooler, when you're running half a second quicker down the track with the same motor.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: what does a 69 Dart with a big block weigh? [Re: 70blackfish] #1131286
12/21/11 01:04 PM
12/21/11 01:04 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I have the best of both worlds , a 69 dart AND a 69 coronet
Re: what does a 69 Dart with a big block weigh? [Re: deaks] #1131287
12/21/11 10:33 PM
12/21/11 10:33 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
A-bodies are cool...B-bodies have more room to work on them. My last B-body race car weighed 3077# at the line...my new/light, all steel except the hood, original glass, A-body, weighs 3300# at the line. Also, my A-body is street legal with all the comforts of home inside. The B-body was 'stripped/gutted/not street legal/cutup/lightened/fiberglass everywhere/lexan/did I mention stipped..' you get the idea and comparison. I also prefer the B-body cars.
If you like drag racing, support your local track.
Re: what does a 69 Dart with a big block weigh? [Re: CHAPPER] #1131288
12/22/11 10:34 AM
12/22/11 10:34 AM
ill
ill
only if it has a small block sitting in it
put 440, 2" headers, shes pretty full too
Page 2 of 3 1 2 3
