Re: what does a 69 Dart with a big block weigh?
[Re: Quicktree]
#1131271
12/11/11 07:00 PM
12/11/11 07:00 PM
Posts: 2,177 ill
dennismopar73
ill
SORRY FOR THE BAD LUCK ON YOUR SCALES, scales can get knocked out, due to no maintance, weather, bad truck drivers, slamming brakes on it worse thing. but if they are cert they have to be accurate +or- within # s not 100s of # why you say, because everyone get paid off scales in almost everything, including gas to cereal , if the scale is cert, and someone is cert it that way , he is not doing his job!
[Re: dennismopar73]
#1131272
12/11/11 08:01 PM
12/11/11 08:01 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Holy crap! Mu simple question turned into a study of validity in scales!! awesome! Anyway, this Dart I'm looking at has dana60 rear axle, that should make quicktree happy. Mike
1969 Dodge Dart Swinger
[Re: MikeyT]
#1131273
12/11/11 08:27 PM
12/11/11 08:27 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
My 68 with bb, aluminum heads, wp, etc..., 727, Dana 60, steelies, FULL interior, etc... weighs 3600.
codfish
[Re: codfish]
#1131274
12/11/11 10:57 PM
12/11/11 10:57 PM
Posts: 116 Eastern Shore of Maryland
nasty68
My 68 all steel except hemi hood, 383, iron head, auto, full exhaust, no power anything, 8 3/4 rear with ladder bars, race buckets, with back seat and a 10pt cage is 3190 without me in it.
68 dart, 383, 727 2013 Jeep JKU Sahara
[Re: codfish]
#1131276
12/12/11 09:12 AM
12/12/11 09:12 AM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
codfish
I believe it. My '76 Dart is a fat turd too.
[Re: MikeyT]
#1131277
12/12/11 09:24 AM
12/12/11 09:24 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
My 71 Demon is right at 3470.The car lost 60 lbs with aluminum heads,water pump/housing and radiator.
440/727/Dana 60.'Glass hood and 1 seat,no carpet 6 pt roll bar.the rest of the car is all steel.
And I will say that Quicktree is correct.On some scales here as I weighed my car/trailer at 2 different scales and the weights were different by over 100lbs.I don't know about OTR scales,I didn't use one of those.Next time I'm using the scale at the race track.
[Re: tboomer]
#1131279
12/12/11 09:54 AM
12/12/11 09:54 AM
Posts: 2,177 ill
dennismopar73
ill
Ok just scaled our 69 dart gts, bb, auto, 8 3/4 all factory, stock wheels, 2 truck scales ,and 1 portable came in at 3360, grain scales said 3380, truck scales on I55 said 3350
[Re: dennismopar73]
#1131280
12/12/11 01:36 PM
12/12/11 01:36 PM
Quicktree
now go to a division or national event race and weigh it and come back and report.
[Re: Quicktree]
#1131281
12/12/11 08:07 PM
12/12/11 08:07 PM
Posts: 2,177 ill
dennismopar73
ill
We have weight it at Gateway ,RT 66,& Indy. Gateway was the heaviest RT66 lightest, Indy same as truck scales on I55, We also have a 68 bb dart gts, weights 100 lighter So have enough scales time with the cars ,25-30# not enough for me to care about carry on
[Re: dennismopar73]
#1131282
12/20/11 01:29 PM
12/20/11 01:29 PM
Posts: 619 nj
JAMESDART
nj
my 69 dart, all steel, steel police wheels with the fronts narrowed, 383, 727, and dana 60, full interior bench seat, headers 3" full exhaust, aluminum rad and intake, manual steering, 11" discs up front 11" drums on back. 3380 lbs on e-town scale.
[Re: lowbudget]
#1131284
12/21/11 11:51 AM
12/21/11 11:51 AM
Posts: 4,152 SO. CAL.
70blackfish
SO. CAL.
Yes, a Dart will be lighter. However, you will never replace the cool factor of the Coronet...just something to consider. I had a 69 Charger at one point and replaced it with my current 69 Dart and always kinda regreted it. Would the Dart always be faster cause of the weight advantage? sure. But the B bodys definately are more stylish (my opinion here) and you dont see them as often at the dragstrip. Especially ones that run quick
I would take a 67-69 dart over any cornet...thats Just my opinion..
[Re: 70blackfish]
#1131285
12/21/11 11:58 AM
12/21/11 11:58 AM
Posts: 3,210 robin hood country
deaks
robin hood country
I have a 69 GTS but i think the 68-9 Coronets are sleeker than the Dart but not the others, personally, i like early E bodies the best and yours is the coolest on here Blackfish. A body's are cooler, when you're running half a second quicker down the track with the same motor. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: 70blackfish]
#1131286
12/21/11 01:04 PM
12/21/11 01:04 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
I have the best of both worlds , a 69 dart AND a 69 coronet
[Re: deaks]
#1131287
12/21/11 10:33 PM
12/21/11 10:33 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
A-bodies are cool...B-bodies have more room to work on them. My last B-body race car weighed 3077# at the line...my new/light, all steel except the hood, original glass, A-body, weighs 3300# at the line. Also, my A-body is street legal with all the comforts of home inside. The B-body was 'stripped/gutted/not street legal/cutup/lightened/fiberglass everywhere/lexan/did I mention stipped..' you get the idea and comparison. I also prefer the B-body cars.
If you like drag racing, support your local track.
