1972 b body spindle interchangibility? #1131117
12/10/11 01:46 PM
12/10/11 01:46 PM
Detroit,Michigan USA!
E
erick72 Offline OP
erick72  Offline OP
E
Is there any car I could pull different but able to bolt up to my 72 knuckle.I can't find rotors for these 70-72 spindles.nothing around me that doesn't want 230 for USA made Wagner's.I've heard possibly f body spindles may bolt up? If I could switch spindles the rotors will be cheaper.thanks in advance for any answers.
Re: 1972 b body spindle interchangibility? [Re: erick72] #1131118
12/10/11 05:52 PM
12/10/11 05:52 PM
E
erick72 Offline OP
erick72  Offline OP
E
Found a 78 volare 4 door front discs and a 75 duster but with drums.will either work?
Re: 1972 b body spindle interchangibility? [Re: erick72] #1131119
12/10/11 09:30 PM
12/10/11 09:30 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
f bodys work well--the same for late A body units---for a neat upgrade watch for cordoba/magnum they use a taller rotor 11.75 and you need to grab the caliper mounting bracket as well because it is taller, sometimes with the 2 pin kelsey hayes calipers which most guys prefer----bob
Re: 1972 b body spindle interchangibility? [Re: erick72] #1131120
12/10/11 09:37 PM
12/10/11 09:37 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I make spindle sleeves that adapt inexpensive '73 and newer rotors to your original '72 and earlier knuckles.
Please E-mail me if you are interested. doctordiff@gmail.com
Re: 1972 b body spindle interchangibility? [Re: DoctorDiff] #1131121
12/10/11 10:17 PM
12/10/11 10:17 PM
E
erick72 Offline OP
erick72  Offline OP
E
Email sent!
Re: 1972 b body spindle interchangibility? [Re: erick72] #1131122
12/11/11 10:59 AM
12/11/11 10:59 AM
Forth Worth, Texas, USA
TheRamMan Offline
TheRamMan  Offline
THE RAM MAN has new replacement rotors( A LIMITED SUPPLY ) for the factory spindle...( 1970 - 1972 B AND E )for factory replacement...heavy duty cop STYLE rienforced hubs,bullit proof for 245.00..for the pair .YES for 245.00 a pair.... not a piece 817 691 5996 ROTORS, YEA. THANK GOD
