Best source for repro pulleys and brackets 4 a 69 HEMI? #1130797
12/09/11 08:55 PM
12/09/11 08:55 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi,
I need pulleys for my 69 HEMI charger engine.
I also need the alternator brackets, etc.
I wonder who makes the most correct repros and has the best price...
Also, what should I do about the alternator and the double pulley that the hemi cars used? I dont have the original alternator.
My car is a power steering car.
Re: Best source for repro pulleys and brackets 4 a 69 HEMI? [Re: domingo] #1130798
12/09/11 10:06 PM
12/09/11 10:06 PM
PEI Canada
chromedome426 Offline
PEI Canada
I am not sure who has the best, but I did order my pulleys and brackets from Mancini Racing.
As for the double pulley alternator, a lot of 80's mopars had the double pulley. So one option is to order a rebuilt one of those.
Re: Best source for repro pulleys and brackets 4 a 69 HEMI? [Re: chromedome426] #1130799
12/09/11 10:20 PM
12/09/11 10:20 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
Re: Best source for repro pulleys and brackets 4 a 69 HEMI? [Re: 2fast4yourBrain] #1130800
12/09/11 11:17 PM
12/09/11 11:17 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
awesome. thanks!
Re: Best source for repro pulleys and brackets 4 a 69 HEMI? [Re: domingo] #1130801
12/10/11 02:40 AM
12/10/11 02:40 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Be forewarned the repop pulleys do not look like the stock pulley's , you'll have to do dome work to them , them , the repop water pump pulley I have is ribbed , some time in a lathe with sand paper should fix that, not sure if the lower pulley is the same.
Re: Best source for repro pulleys and brackets 4 a 69 HEMI? [Re: JohnRR] #1130802
12/10/11 11:43 AM
12/10/11 11:43 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
OK John. Good info. But are they dimensionally the same? I wont run into pulley alignment issues with the repro pulleys? and shaped the same other than that ribbing issue you point out?
Re: Best source for repro pulleys and brackets 4 a 69 HEMI? [Re: domingo] #1130803
12/10/11 12:25 PM
12/10/11 12:25 PM
PEI Canada
PEI Canada
I think the only problem with alignment would be depending on what you have for a balancer. ( thick or thin ).
Something tells me the original Hemi's had a thicker balancer than the B/RB or crate engines.
The pulleys I got for my Hemi crate engine was for a B/RB engine.
They do make the pulleys for both styles.
Re: Best source for repro pulleys and brackets 4 a 69 HEMI? [Re: chromedome426] #1130804
12/10/11 12:32 PM
12/10/11 12:32 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I have a NOS factory balancer!
