Re: Turbo Question HELP needed!!
[Re: 74dust]
#1130314
12/09/11 02:38 AM
12/09/11 02:38 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I dont have any specs but a 6.5 is a fair bit bigger than a 318 so by rights it should have enough in it to scatter a 318 pretty easy..... just a guess... but it would make a difference when it start to spool
[Re: 74dust]
#1130317
12/09/11 05:28 PM
12/09/11 05:28 PM
MR_P_BODY
The engine I have is already built to 400 hp I was wondering if this was large enuf to be a decent power adder or if I will need 2?
Just 1.... try to find the map for that unit
[Re: 74dust]
#1130318
12/09/11 09:44 PM
12/09/11 09:44 PM
Posts: 1,572 Jacksonville Florida
elitecustombody
Really depends on what you mean decent power, but I'd say it's large enough to gain couple hundred easy.I mess with Turbo Supras ,the little 3 liter can put down 700+ on 67mm turbo,but that's with high quality billet turbo,right supporting mods,good tuner that knows what he's doing to get all the power out of your combo.Dealing with turbo cars can get very expensive.Good set of cams,good flowing head with extensive head work,right exhaust manifold,wastegate,intake mani,t/b,lightened,ballanced, built bottom end with forged rods & pistons,billet dual or triple ballbearing turbo and you got over 40k under the hood Get a good fuel pump and turn up the boost.BTW, I'm assuming you built the motor with lower compression for boost. Otherwise it wouldn't be safe to run past 8 psi.
