What 4speed gear oil #1130223
12/08/11 10:56 PM
12/08/11 10:56 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Hopefully finishing up this weekend and need to add gear oil to the tranny. Any recommendations for gear oil. I'm assuming like an 80/90 but need advice. Also regular dino or synthetic?
Thanks in advance!
Re: What 4speed gear oil [Re: slowpoke] #1130224
12/08/11 11:00 PM
12/08/11 11:00 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
This topic is a hot one on here. We use regular ole' 90 weight gear oil in ours.
Re: What 4speed gear oil [Re: slowpoke] #1130225
12/08/11 11:01 PM
12/08/11 11:01 PM
Kirkland, Washington
Pacnorthcuda Offline
#1 tip: DON'T use a GL-5 lube (and most of them are)...Use a GL-4!!!
I like Redline's synthetic offerings; MTL, MT-90 etc. Other good ones are Pennzoil Synchromesh and Amsoil lubes.
Re: What 4speed gear oil [Re: slowpoke] #1130226
12/08/11 11:01 PM
12/08/11 11:01 PM
IMGTX Offline
IMGTX  Offline
Back in the day..
The factory suggested ATF for shifting.
I liked 90w but would mix in ATF in the colder months to help shifting.
Good news is Jamie Passon (Passon Performance) has a proprietary fluid he sells specifically for our old Mopars.
I haven't tried it yet but I haven't heard anything bad about it.
Re: What 4speed gear oil [Re: IMGTX] #1130227
12/09/11 01:13 AM
12/09/11 01:13 AM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
PENNZOIL SYNCHROMESH works great !!!
Re: What 4speed gear oil [Re: slowpoke] #1130228
12/09/11 03:40 AM
12/09/11 03:40 AM
Straight ATF, I used in many NP833 on the street and at the track on drag race only Hemi cars So did the many of the new car Mopar factorys
Re: What 4speed gear oil [Re: dustergirl340] #1130229
12/09/11 11:38 AM
12/09/11 11:38 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
....90 weight
Re: What 4speed gear oil [Re: DAYCLONA] #1130230
12/09/11 01:16 PM
12/09/11 01:16 PM
dogdays Offline
dogdays  Offline
As mentioned above, you don't really want to use a GL-5 gear lube in a synchronized transmission.
The reason is that all GL-5s contain Extreme Pressure (EP) additives. They chemically react with the surfaces of the metal parts and form oxide layers that are a last ditch defense against metal-to-metal contact. This is especially important in automotive rear drive axles. The hypoid gearing requires some sort of EP because of the rubbing, sliding contact. I believe EP gear oils were the result of or made necessary by hypoid gearing.
The EP additive package therefore is by nature corrosive. If all the parts are ferrous, that is no problem. But if there are copper alloys the additive package attacks them too and maybe preferentially to ferrous metals. Your synchronizers are a copper alloy and they act as brakes, relying on friction. EP additives attack the synchronizers and the resultant surface film of oxides reduces the synchronizer's abilities.
Sure, millions of standard transmissions are in use with a GL-5 oil, I own at least four. BUT use of a GL-4 fluid will make shifting better in almost every (transmission) case.
R.
Re: What 4speed gear oil [Re: dogdays] #1130231
12/10/11 03:37 AM
12/10/11 03:37 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
The factory acknowledged that ATF was harder on some 4spd parts over a period of time and recommended gear oil for some conditions/applications.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: What 4speed gear oil [Re: MY340] #1130232
12/10/11 10:46 AM
12/10/11 10:46 AM
IN
ahy Offline
ahy  Offline
IN
If you will be doing a lot of cold weather driving, the lighter fluids like ATF can help shifting... but I'll guess you aren't and agree they aren't the best for durability. Some of the newer ATF formulations are really hard on syncros.
OK would be regular 80W90 or 75W90. Better would be GL4 80W90. I have found shifting is noticably better with the specialized synthetic lubes. I have used and would recommend Redline "MT90". Its a full synthetic multi-visocosity manual transmission lube. I get it from Summit. I'm sure the Passon lube is similar and works well; I just haven't used it.
If you really need a lighter fluid, "Sycromesh" will be similar to ATF but with an additive package designed for manual transmissions. Its used in modern MT's and available at most parts stores. My local Autozone usually keeps a few quarts on hand. The lower viscosity Redline MTL would be good also. Similar to the "MT90" but lower viscosity.
Re: What 4speed gear oil [Re: ahy] #1130233
12/10/11 03:24 PM
12/10/11 03:24 PM
Retired now in Tennessee
Chi_Town_Runner Offline
I used Passon's in 2 different A-833 transmissions and noticed a marked improvement in operation.
Just my
Good Luck.
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: What 4speed gear oil [Re: Chi_Town_Runner] #1130234
12/12/11 09:40 AM
12/12/11 09:40 AM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Thanks again!
Re: What 4speed gear oil [Re: slowpoke] #1130235
12/12/11 04:59 PM
12/12/11 04:59 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
back in the day the tranny place I used put 50% 30W oil and 50% ATF in.
