Re: using synthetic motor oil, what viscosity to use??
[Re: Junky]
#112978
09/01/08 11:49 AM
09/01/08 11:49 AM
Posts: 21,845 Kirkland, Washington
Pacnorthcuda
Shell Rotella T 5W40 synthetic in my 383. Plenty of zinc to protect the valves.
I would think you would be choosing a high zinc oil to protect the cam/lifters... ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Captain Flapjack]
#112981
09/04/08 05:08 AM
09/04/08 05:08 AM
Posts: 4,866 N. of 8mile, S. of heaven
Spike
Go Blue!!
Go Blue!!
a friend has some extra penzoil 5w 30 synthetic
is that ok?
When you start getting into the 5W-30, 0W-30, etc you have to be concerned with the zinc content. It may need more zinc to help protect your cam.
[Re: Spike]
#112982
09/04/08 05:44 AM
09/04/08 05:44 AM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
is that ok?
Very true, most of the 0W, and 5W oils that I know of currently are the lower zinc 800 ppm API SM rated lubes. One exception I know of, and there may be others, is Amsoil’s SAE 5W-30 Synthetic Heavy Duty Diesel Oil. The zinc level in this oil would provide excellent protection for a flat tappet cam with 1379 ppm of zinc. Also, the High Temperature/High Shear Viscosity (ASTM D-4683) of this lube is 3.4, so this oil has great film strength for greater protection under heavier loads. This oil was designed for heavy duty diesel engines and improved fuel economy, but useful in high performing gas engines requiring higher levels of zinc.
Amsoil 5W-30 Synthetic Heavy Duty Diesel (HDD) link
CompSyn
