LED Dash instrument flood lights?
#1129607
12/07/11 07:37 PM
12/07/11 07:37 PM
Posts: 297 Oklahoma
TinCuda
Oklahoma
1971 'Cuda
I have been kind of kicking around the idea of replacing my dash flood lights with green LEDs. I have heard of some folks doing this and I was wondering if that was a plug and play kit that they got somewhere or if they just wired them in.
Thanks for any info
(O O {]{]{]||[}[}[} O O)
1971 Plymouth 'Cuda 440-6
{||O||}
2000 Yamaha V-Max
(O O [========= SRT] O O)
2011 Dodge Challenger SRT 392
Making as big as a carbon footprint as I can!!!
Re: LED Dash instrument flood lights?
[Re: TinCuda]
#1129608
12/07/11 10:06 PM
12/07/11 10:06 PM
RapidRobert
Well I bought some blue and green 1157 and 1156 bulbs from www.classicindustries.com. Ain't use them yet (& maybe illegal ) but looking forward to it. Here's a BTT for ya
[Re: abodyjoe]
#1129610
12/08/11 01:52 PM
12/08/11 01:52 PM
Posts: 5,904 Athens, Greece
Pyper70
Athens, Greece
$5 each? Thats highway robbery. I paid $0.75 each . I bought 10 and it was free shipping from China from you know what site.
Plenty bright. I went for the super white bulbs. You can't dim them but they look pretty sweet in the dash and on the console. If I could find one for my Autometer tach now that would be great
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: screamindriver]
#1129612
12/08/11 09:57 PM
12/08/11 09:57 PM
Posts: 4,730 Florida
BDW
Not sure which LED route you're going but keep in mind...The "green" tint is actually produced by the lightbulb's lense covering...You would'nt actually need a colored bulb unless your original dash lenses are shot...
Found this out the hard way. I went back to the old standard bulbs and it looks much better. The LEDs just weren't bright enough and way too expensive to keep playing around with to get a color match.
[Re: TinCuda]
#1129614
12/09/11 04:33 PM
12/09/11 04:33 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I put LEDs in my 92 D250 and the Imperial. They dim just like the original lights. My LEDs came from superbrightleds.com. Here's a couple shots to show the range. It's a very linear progression. I very rarely keep the gauge lights all the way up. It's pretty bright. I will give you a word of warning. Don't use the brightest LEDs for your indicator lights. I did that in my truck. When I hit the turn signal the interior of the truck flashes green. It's way too bright. Using the hazard lights is almost blinding at night. Use green LEDs for green lights and other colors for other color lenses. If you put a white LED behind a green lens like those turn signal indicators the LED color will blow through the tinted lens. A white LED behind the green lens would be a white light with a slight green tint. White LEDs in tail lights will shine a very pale pink. Always match the LED color with the lens color. My truck's gauge lights are cool blue LEDs with the original blue bulb covers. I put ultraviolet LEDs in the dash flood lights in the Imperial. Since the gauges are lit from the dash pad and not from behind the gauges the UV LEDs reduce glare while really making the gauge markings and needles pop nicely.
[Re: Pyper70]
#1129617
12/09/11 07:25 PM
12/09/11 07:25 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
You can't dim them but...
So you screwed up its proper function....
To you I did but I always have my lamps on at their brightest. My LEDs give a turquoise blue accent to the entire dash. I don't even dim the lights in my 2004 Chevy.
Yah. I understand you don't mind but they're supposed to dim. I never let the next owner of one of my cars have to say "What the ^%$# did this guy do???" Maybe you play the radio loud. Are you going to remove the volume knob? Small and very petty... YES. But it's the devil in the details that I like attending to.
[Re: Pyper70]
#1129620
12/09/11 10:53 PM
12/09/11 10:53 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I bought some from the same site, same country, possibly different seller. The first time was a set of 10 for $9.99 shipped. They looked great for a bout a month, then started strobing And then eventually went out.
I recently bought a replacement set, from a different seller, slightly different bulb design, so far so good. Same price, same country. If these fail shortly, I will check into some of the higher priced bulbs. I don't know if the higher price, will bring better quality or not.
I used the bright blue LEDs to match the stereo and CB i have in the truck.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: 71rm23]
#1129622
12/10/11 01:29 PM
12/10/11 01:29 PM
feets
Senior Management
Senior Management
Irving, TX
No resistor required on my vehicles.
Cars that have warning lights for burned out bulbs usually require some sort of resistor. If the car doesn't see enough of a current draw it will give you the warning. LEDs draw very little current and will set off those warnings. Old school thermal flashers (used in all older American cars) will not work properly with LEDs as turn signals. The fix is a cheapie electronic flashed. You're right back to plug and play.
