Re: LEAKING GOOSE NECK
[Re: 76michmac]
#1128834
12/06/11 03:21 PM
12/06/11 03:21 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
REPLACE IT WITH A CHICKEN THROAT!!!!!
[Re: 1_WILD_RT]
#1128835
12/06/11 03:49 PM
12/06/11 03:49 PM
Challenger 1
Cincinnati, Ohio
Silcone is your friend and the only way to seal em up. If it's chrome, replace it and use silcone to seal it, no gasket.
[Re: MR_P_BODY]
#1128837
12/06/11 04:57 PM
12/06/11 04:57 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
THREE TIMES I,VED TRIED TO GET GOOSENECK TO STOP LEAKING AT MANAFOLD, ANY IDEAS? 360 DUSTER AUTO
Take some sandpaper on a flat surface and hit the bottom of the housing to see if its flat... make sure the intake is clean... the stat drops into the intake(groove) then the gasket on top of the stat... might still use silicone even with the gasket... also make sure you havent cracked the housing Some intakes dont have the groove so the stat would have to go into a groove in the housing... make sure one of them has the groove
And turn off your caps lock
[Re: JohnRR]
#1128838
12/06/11 09:06 PM
12/06/11 09:06 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
Gregg(Roadhazard)has the gasket you need just send him a PM with your info about your manifold and T-stat housing.I have a chrome neck and one of his gaskets and ZERO sealer and it is bone dry. Best damn gaskets in the world Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 76michmac]
#1128839
12/06/11 10:30 PM
12/06/11 10:30 PM
Posts: 392 Doniphan, Nebraska
Lmopar69
Doniphan, Nebraska
Had the same problem with my 318 the other day. Edelbrock manifold and an aluminum water neck. Did just as was suggested above. Put sand paper on a flat surface and sanded it a bit, it was BADLY warped. So, I sanded it down flat, put on a little gasket sealant and a new gasket. No problems now.
Laine.
NRCA Member
[Re: Lmopar69]
#1128840
12/07/11 12:41 PM
12/07/11 12:41 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I think they make those T-Stat housings warped from the factory As said a clean FLAT surface and you're golden I had about an hour in getting mine srtaight first a file then some sandpaper wrapped around a flat piece of steel. Now I have one of my gaskets on it with NO sealer been dry for years. Thanks for the kind words Gus
