Re: m/t 28x10.50 on a 12" wheel
[Re: ALKYW5DART]
#1128568
12/06/11 04:24 AM
12/06/11 04:24 AM
Posts: 43,303 Bend,OR USA
Cab_Burge
anybody run a 28x10.50 m/t slick on a 12" wheel i have been told the tread will not ballon out will lay flat. also need to know the section with to see if it will fit on my dart. i currently have 10" wheels that fits great but don't know if 12" will fit, thanks guys
Don't believe those that say the sidewall will not become wider on a wider wheel Thank about that your going to move the bead of the tire out one inch more per side, don't you think the section width will get wider also Trust me, it will I have done that test on both bias plys and radials, every time the section width got wider when I used the same tire on a wider rim BTW, if you have a 1.5 inches or more side clearances now go for it If you can live with 1/2 inch clearance to the tire ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: 5126brl No more]
#1128570
12/06/11 11:27 PM
12/06/11 11:27 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
i run my dart with 29.5 true 10.5's on a 12" rim and also have a customer running 28 true 10.5's on 12". If my memory is right both are right around 13.2 on the bubble.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: ALKYW5DART]
#1128572
12/07/11 01:59 AM
12/07/11 01:59 AM
Posts: 304 Maryland
SLEDGEHAMMER
Maryland
See sig for mine with a M/T 28x10.5 on a 12" rim.
1971 Dodge Dart - Powerplant <<TBD>>
