Re: Aluminum rods on street??
[Re: vttm]
#1128277
12/05/11 06:58 PM
12/05/11 06:58 PM
Drive it, melt tires , have fun No worry!! If it was built right, it will be Fine!
[Re: joshking440]
#1128281
12/05/11 09:04 PM
12/05/11 09:04 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Yea you just don't beat on them till there up to temp.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: vttm]
#1128282
12/05/11 09:04 PM
12/05/11 09:04 PM
Posts: 30,443 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
would it be possible to run aluminum rods for short distances on the street say 10 miles or so? School me on who's correct and why.
10 miles is a STREET CAR ? ..
HOPPING ON 95 and driving to FL from MD is a STREET CAR ...IMHO !
[Re: jim sciortino]
#1128285
12/06/11 03:06 AM
12/06/11 03:06 AM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
BME says their rods are fine for the street. Its all about using good oils. http://www.bmeltd.com/rods.htm
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: HOTMOPR]
#1128286
12/06/11 03:34 AM
12/06/11 03:34 AM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Done it many times with zero issues. In fact we use to use or old race rods in street engines all the time.
[Re: vttm]
#1128287
12/06/11 12:38 PM
12/06/11 12:38 PM
Posts: 4,207 New York
polyspheric
New York
Ah yes. The Forum, where everyone's opinion has equal value.
Boffin Emeritus
[Re: dogdays]
#1128289
12/06/11 02:34 PM
12/06/11 02:34 PM
Posts: 292 NY
challenger451ci
NY
It has nothing to do with temperature.
It is all about fatigue life. Let's take steel for an example. As steel goes through millions of tension/compression cycles its strength goes down. At some point the strength levels out, IIRC at about 57% of new. Then the curve of strength vs. cycles is flat. Now let's look at aluminum. As the cycles mount up the strength goes down...and down...and down. The curve never levels off. It continues until it hits zero. By that time your aluminum part has long since broken. Sounds bad, doesn't it? But there is a question. How come some aluminum parts last longer than we would expect? I think it has to do with the amount of cyclic stress to which the aluminum part is subjected. Maybe the curve becomes less steep if the part is only stressed to, say, 50% of yield or ultimate. Then the acceptable service life would be extended past the time that an overhaul was needed.
Does anyone have any references for this?
R.
IIRC, in order for the part to fatigue, it has to be loaded (stressed) above the fatigue strength. If the rods are designed so that at a given bobweight and RPM limit, no section is loaded beyond the fatigue strength rating, they'll theoretically last forever in that application. Big question is, how sure can you be that you're under the fatigue strength???
[Re: dogdays]
#1128291
12/06/11 09:50 PM
12/06/11 09:50 PM
polyspheric
New York
All Triumph and BSA 750 3 cylinders had aluminum rods. 7,000 RPM engine. 70,000 miles reported frequently.
Boffin Emeritus
[Re: dogdays]
#1128292
12/07/11 02:56 PM
12/07/11 02:56 PM
Posts: 292 NY
challenger451ci
NY
No. As the aluminum part fatigues the strength keeps going down as the number of cycles goes up. It eventually goes to zero.
What you are describing is for steel, where it levels out at some point.
That's why people don't worry so much about steel connecting rods.
But I'm not sure if a cycle at say 10% of the new tensile stress is the same as a cycle at 90% of the new tensile stress. I am looking for that answer. A lot of this metallurgical stuff isn't "logical" unless you're a metallurgist.
Briggs&Stratton engines use aluminum connecting rods.
Suppose your part will break at 10 million cycles. How many miles is that?Let's use a 27" tire and 3.91 gears. Assume all of the mileage is in High gear. So you have 2,921 revolutions per mile at the crankshaft. How does 3,423.9 miles sound?
I'm back to liking steel rods more and more.
R.
If you NEVER load the part past the fatigue strength it will NEVER fatigue. I understand that this number is not a constant once the material BEGINS to fatigue. The point I'm making is the material won't ever fatigue if it is not loaded past the fatigue strength. An aluminum part will have a fatigue cycle limit at a given load. If you're below that, fatigue doesn't enter into the equation. BTW, the tensile stress in a given part at a given load is the same regardless of fatigue strength of the material.
I think this is why a properly applied (overkill) aluminum rod will last virtually forever. If the rods are not properly applied, they will have a life cycle. Since this is not easy to measure in an engine, most engine builders change rods after X-number of cycles as an insurance policy just in case the rods are stressed to beyond the fatigue strength.
[Re: dogdays]
#1128295
12/07/11 08:49 PM
12/07/11 08:49 PM
UUmmmm... like we were saying----Run them, have fun, melt tires. Too much science , not enough rubber burning here. And that opinion is based on experience.
