what are you working on?
on my 85 truck i used the 12volt power wire from the egr time delay relay,as I ditched the egr stuff.
if it had the choke oil pressure sender and the choke warmer set up yo would just use the power wire from that...this would be the 3 prong pressure switch that is on a tee with the oil gauge sender on a SB,the choke heater would be the little gizmo thats on the intake at the coil bolt with a radio noise suppreser(I think?) has wires on it and a ground to the choke piece on carb.
any keyed 12volts should work
the eddy spredbore to square bore adaptor is what the plate is refered too. it put the eddy carb on a spredbore intake
not needed on a eddy squarebore intake but,but a eddy 3/8" fiber gasket(divided or open plenum/depending on intake flange) is recomended to reduce heat and make a good seal on carb base.
I run a stacked alum plate/gasket heat disapator( on my weiand intake and eddy carb) which is a 1/2" stacked 4-hole spacer.
my carb is luke warm after a 40 mile ride and you cant touch the intake but for a second or two
you will need the mopar throttle lever and a stock thorottle stud also
I run manual choke with the heat blocked off the the alum intake cross over,
