Page 1 of 3 1 2 3
Caltrac question... monos or xhd leafs? #1127826
12/05/11 01:49 AM
12/05/11 01:49 AM
WI, USA
67dodge67 Offline OP
mopar addict
mopar addict
WI, USA
I finally said wth and got them. I have been told by several people that yes you can use xhd leafs OR the monos with successful results. Quick run down on my car: 67 Coronet, 470, 727 w/ 9.5" PTC (thank you Cope!), 4.10 Dana, 325x15x50 M/T drag radials, 90/10's front, stock rear shocks (I know, bad...) and xhd leafs, previous consistent 1.65 60's, best 1/4 of 11.80. I am sure I'll get the comment "use this or that rear shock" which is fine, but I'd like to know if there is a HUGE difference using the xhd's compared to the monos Caltrac offers. If I can hit low 11's next year (have done some head work, roller cam, 950 annular and other things) I'd do backflips. Thanks for your input everyone.
Re: Caltrac question... monos or xhd leafs? [Re: 67dodge67] #1127827
12/05/11 02:31 AM
12/05/11 02:31 AM
Renton Washington
Triple Threat Offline
Renton Washington
Mono's would be better, and lighter, but the XHD's will probably work. You already have them so i'd give it a shot before spending another $330 on leafs.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Caltrac question... monos or xhd leafs? [Re: 67dodge67] #1127828
12/05/11 10:52 AM
12/05/11 10:52 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
You really have to have their monoleafs. The Cal Trac bars do not work up to their potential with s multi leaf type spring.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Caltrac question... monos or xhd leafs? [Re: Triple Threat] #1127829
12/05/11 10:56 AM
12/05/11 10:56 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
For one with the heavy springs and those shocks you would be very disapointed with the resaults. you have absolutly no control and the caltracs would not work right. You need a shock that you can tighten up to control rap up. Using the heavy springs also makes it harder to control. Get the mono and their shocks.
JAKES AUTOMOTIVE
Re: Caltrac question... monos or xhd leafs? [Re: JAKE68] #1127830
12/05/11 11:17 AM
12/05/11 11:17 AM
PA
moparacer Offline
moparacer  Offline
PA
If it were mine I would try the car without the cal tracs first and see how it does. Then put the cal tracs on it and try it...
I just pulled a set of cal tracs off of a Barracuda that I am building that had worn out SS springs.
Going with the XHD springs and nothing else.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Caltrac question... monos or xhd leafs? [Re: 67dodge67] #1127831
12/05/11 11:25 AM
12/05/11 11:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A friend uses HD springs with the caltracs and a
set of good shocks... for what his set up is he
does real good with a 1.49 60'
Re: Caltrac question... monos or xhd leafs? [Re: MR_P_BODY] #1127832
12/05/11 11:38 AM
12/05/11 11:38 AM
Bergen County NJ
N
NoJoke Offline
NoJoke  Offline
N
Bergen County NJ
I have a set of Caltracs but I have to get leafs to work with my car. I have SS springs now but I can run a spring that will sag I will have tire clearance issues if it does. I think Caltracs makes a mono leaf with 1" extra height... It's a street car that I take to the tracks a few times a yr... Does anyone run mono leafs on the steeet?
Re: Caltrac question... monos or xhd leafs? [Re: NoJoke] #1127833
12/05/11 11:44 AM
12/05/11 11:44 AM
Renton Washington
Renton Washington
Caltrac's and Split Mono's here. Car gets driven on the streets a lot. It made the drive to the car show/ toys for tots charity run yesterday.
-Dustin
Re: Caltrac question... monos or xhd leafs? [Re: Triple Threat] #1127834
12/05/11 11:52 AM
12/05/11 11:52 AM
Bergen County NJ
N
NoJoke Offline
NoJoke  Offline
N
Bergen County NJ
How long have you had them leads on your car? Have they sagged on you at all? How is the ride hard?
Re: Caltrac question... monos or xhd leafs? [Re: NoJoke] #1127835
12/05/11 12:11 PM
12/05/11 12:11 PM
WI, USA
mopar addict
mopar addict
WI, USA
Thanks for the replies here. I think I am going to put them on and see how things go. I'm also saving up for a decent pair of shocks as well... tax return!! After having some trial runs with the set up next year, I'll determine if mono's are needed.
Thanks again,
Re: Caltrac question... monos or xhd leafs? [Re: 67dodge67] #1127836
12/05/11 12:16 PM
12/05/11 12:16 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I've run 1.60's w/ these XHD springs and drag radials, I just stepped up to Diff Dr axles and a set of cheap slapper bars. Looking for 1.55's or so. What is your current set up? Are you spinning? How are you aluching the car? What's the MPH at 11.80? I'm going to try the slapper bars before I shell out the cash for Cal-Tracks. Buddy of mine cut 1.50 60 foot times w/ a 590 cammed, E-headed 440, 4.56's, 318 leaf springs and traction bars. (11.0 car)
Keep us posted on how much they help...
Coming soon!!!!
Re: Caltrac question... monos or xhd leafs? [Re: Mr.Yuck] #1127837
12/05/11 12:47 PM
12/05/11 12:47 PM
Toronto
mshred Offline
mshred  Offline
Toronto
If you already have the XHD's I would try them and see how it does...my car runs mid-low 12's and best 60 was 1.69 with a 4 speed and caltracs with 6 cyl multileafs
something to keep in mind is that when caltracs first came out there were no caltrac monos, guys were using them with multileaf springs
good luck
Re: Caltrac question... monos or xhd leafs? [Re: Mr.Yuck] #1127838
12/05/11 01:21 PM
12/05/11 01:21 PM
PA
moparacer Offline
moparacer  Offline
PA
Just my opinion but cal tracs are better suited for quicker cars that really 60 foot. Like sub 1.40s.
I have a bone stock suspension duster that goes consistent 1.40 60 fts with nothing more then an anti roll bar and 1 spring clamp, on a 9 inch slick nonetheless.
Re: Caltrac question... monos or xhd leafs? [Re: NoJoke] #1127839
12/05/11 01:37 PM
12/05/11 01:37 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i run the mono spring on the street,heavy 69 b-body w/6pt bar.7 years no sag yet.it does seem rough when you hit bbig bumps but what da hey ITS A HOT ROD!!!
Re: Caltrac question... monos or xhd leafs? [Re: bonefish] #1127840
12/05/11 02:44 PM
12/05/11 02:44 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have split mon's with cal-tracs on my 70 Challenger. Have not had a chance to test them out yet.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Caltrac question... monos or xhd leafs? [Re: 6PKRTSE] #1127841
12/05/11 02:57 PM
12/05/11 02:57 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I have Cal Trac's and Split Mono's on my car, and run it on the street all the time. It's a little harsh, but no big deal for me. The biggest difference for street use I noticed was the Aluminum bushings transfer alot more sound from the rear-end to the chassis. I run this setup with Summits adjustable drag race Shocks set at 40/60 (extra firm) out back and 90/10 up front.
Re: Caltrac question... monos or xhd leafs? [Re: Mr.Yuck] #1127842
12/05/11 03:21 PM
12/05/11 03:21 PM
WI, USA
mopar addict
mopar addict
WI, USA
The current rear set up is nothing special... just the xhd leafs and stock shocks, which is why I said I'm getting better ones next year. The last time I went to the track, my 60's were horrible (1.8x - 1.9x) but that was also before I did the recent work as mentioned in my first post. With my old set up (no head work, no roller, no carb, same m/t drag radials, same leafs/shocks) I was very consistent with 1.65 60's. The mph was 113 ish for the 11.80 time, that was before I realized jetting a carb gets the mph up there.
Bottom line is, yes, I had wheel spin off the line, foot brake launch at ~1800 rpm, M/T 325x15x50 drag radials set at 18 psi. My decision to purchase the caltracs came after talking to several people here who were at the track and watched how my car reacted off the line (fellow mopar guys here in town). It's a mixed bag of who runs what for rear suspension - either monos or leafs... which is why I thought I'd ask here to get yet another point of view.
Sorry for the long response, but I do appreciate the replies from everyone. Thanks.
Re: Caltrac question... monos or xhd leafs? [Re: 67dodge67] #1127843
12/05/11 03:48 PM
12/05/11 03:48 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
It will be intresting to see how much you pick up. every tenth at the 60 foot is 2 down track. I'm running cheap gas-matic shocks not sure if they help or hurt.
Re: Caltrac question... monos or xhd leafs? [Re: NoJoke] #1127844
12/05/11 04:12 PM
12/05/11 04:12 PM
Renton Washington
Renton Washington
About 3 years now, mine were -1" to start with but have not sagged at all. The car does ride a little harsh, but the aluminum bushing and having preload in the bars I believe is what causes that. No so much the mono's.
-Dustin
Re: Caltrac question... monos or xhd leafs? [Re: Triple Threat] #1127845
02/19/12 11:33 PM
02/19/12 11:33 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
If I were to run the XHD springs with caltracs, what length springs do I need for a 68 B-body?
Page 1 of 3 1 2 3
