Re: SB conversion into Fox mustang
[Re: hookNgone]
#1127452
12/04/11 04:10 PM
12/04/11 04:10 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
You will have to run a motor plate and a 904 trans. I could help with both ![](/ubbthreads/images/graemlins/thumbs.gif) . Might be easier to make valve cover adapters and lie.
"Just a Bracket car dressed up like a streetcar"
[Re: hookNgone]
#1127453
12/04/11 06:12 PM
12/04/11 06:12 PM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
Just for the weekend? Save yourself the hassle and either switch for good or stay with your current combo.
[Re: fasthawk6]
#1127458
12/04/11 06:48 PM
12/04/11 06:48 PM
Posts: 21,086 Niles , Ohio
therocks
Niles , Ohio
There is a guy around here that has a 440 -727 in one. He said it fit rite in.
Chrysler Firepower
[Re: redruM]
#1127461
12/04/11 07:29 PM
12/04/11 07:29 PM
Posts: 1,030 ohio
67mprfan
ohio
There a another gut on here that put a 440 in a t-bird.......
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#1127462
12/04/11 07:48 PM
12/04/11 07:48 PM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
Its amazing how well different motors fit in that engine compartment. Ever seen a BB chevy in one? It looks right at home and easy to work on.
68 Barracuda Formula S 340
[Re: cudaboy]
#1127466
12/04/11 08:58 PM
12/04/11 08:58 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
duster440w8 on here had one with his 440" w8 motor in it. Best way would be glide and motorplate.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1127467
12/04/11 11:46 PM
12/04/11 11:46 PM
Posts: 35 Minot, ND
darndart
Minot, ND
The guy with the 440" W8 motor in the Fox Body, name is Jesse. He is local to me, but has since sold the Fox and Bought a 70 Duster to put his motor into.
73 Dart Sport 340, 410ci, Indy 360-2 230CNC. 72 Demon 340 4-speed 01 Ram Quad Cab 89 Mustang LX Boss 331,C4,HP76mm turbo, FAST EFI 86 Mustang GT 5.0 AOD 82 Capri RS 306, Fox Lake Stage 1 TW, N41, T5,etc.
[Re: Just-a-dart]
#1127469
12/05/11 10:37 PM
12/05/11 10:37 PM
Posts: 912 London, England
mopar_mark
London, England
I would seriously consider this one ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: Just-a-dart]
#1127470
12/05/11 11:00 PM
12/05/11 11:00 PM
Posts: 25 lower left, ca.
hookNgone
lower left, ca.
You will have to run a motor plate and a 904 trans. I could help with both . Might be easier to make valve cover adapters and lie.
If i show up with the one of the most hated cars in history to an all Mopar event, i better have a pentastar product under the hood. I imagine they will look deep at tech.
