In need pics of 71 cuda brake/fuel routing pics #1127425
12/04/11 02:31 PM
12/04/11 02:31 PM
GA
roadrunninMark Offline OP
GA
I need some pics for the brake line routing on a 71 barracuda/cuda as I am changing from drum to disc. I bought the 2 new valves - proportioning valve and the distribution valve along with the 2 piece front to rear brake line. Since I didn't have this before and the car was half apart when I bought it, I do not know where the the proportioning valve mounts, in which direction, and such. If someone could shoot some detailed pics for me of routing and all I would greatly appreciate it!
Also if it isn't too much trouble, the same for the fuel lines, especially the ECS lines as they were missing. I bought them but I don't know if I will use em.
Thanks again, can email me the pics at midairmark2@aol.com
Re: In need pics of 71 cuda brake/fuel routing pics [Re: roadrunninMark] #1127426
12/06/11 12:20 AM
12/06/11 12:20 AM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
Amazing how an unchallenged lie can become the absolute truth.
Re: In need pics of 71 cuda brake/fuel routing pics [Re: roadrunninMark] #1127427
12/06/11 01:03 AM
12/06/11 01:03 AM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
2
Re: In need pics of 71 cuda brake/fuel routing pics [Re: roadrunninMark] #1127428
12/06/11 01:12 AM
12/06/11 01:12 AM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
3
Re: In need pics of 71 cuda brake/fuel routing pics [Re: roadrunninMark] #1127429
12/06/11 01:13 AM
12/06/11 01:13 AM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
Re: In need pics of 71 cuda brake/fuel routing pics [Re: roadrunninMark] #1127430
12/06/11 01:18 AM
12/06/11 01:18 AM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
Re: In need pics of 71 cuda brake/fuel routing pics [Re: beepbeep] #1127431
12/06/11 09:58 AM
12/06/11 09:58 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Nice to see you posting again Beepbeep, Thanks
Re: In need pics of 71 cuda brake/fuel routing pics [Re: roadrunninMark] #1127432
12/06/11 10:01 AM
12/06/11 10:01 AM
Cincinnati, Ohio
Cincinnati, Ohio
The brake lines, booster, master cyl and rubber hoses are different along with the proportioning valve. I converted my 71 from drum to disc and just ordered everything for disc. Everything bolted up fine and worked. My suggestion is to not mix the drum brake parts with your disc brake parts.
Good luck.
Re: In need pics of 71 cuda brake/fuel routing pics [Re: roadrunninMark] #1127433
12/06/11 10:26 AM
12/06/11 10:26 AM
Cincinnati, Ohio
Cincinnati, Ohio
Having a return line is recomended by me, set it up/order fuel lines for hemi or 440 6 pack.
Re: In need pics of 71 cuda brake/fuel routing pics [Re: Challenger 1] #1127434
12/07/11 01:09 PM
12/07/11 01:09 PM
GA
GA
AWESOME, thanks for the pics!!!!!
Challngr - can you give me a close up shot of the distribution valve/ proportioning valves?
Beep - what book are those out of?
Re: In need pics of 71 cuda brake/fuel routing pics [Re: roadrunninMark] #1127435
12/07/11 02:06 PM
12/07/11 02:06 PM
GA
GA
this is the valve in particular I am having trouble with. Looking at Beeps #2 pic, looks to go under the drivers floor board. Which opening is the "flow in" and which is "flow out"? Also, does it bolt to the body with that bolt it came with?
Re: In need pics of 71 cuda brake/fuel routing pics [Re: roadrunninMark] #1127436
12/07/11 02:53 PM
12/07/11 02:53 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Mark,
You should not be using the valve on the frame rail. Jan 70 it was put into the dist block under master cylinder.
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: In need pics of 71 cuda brake/fuel routing pics [Re: VCODE] #1127437
12/07/11 03:22 PM
12/07/11 03:22 PM
GA
GA
Hi Bob, I thought that was the case and I questioned this but I was told I needed 2 valves for non powered disc brake cars (I am converting from drums up front to the 11 3/4 junkyard setup). Here is the second valve they said I needed. Also what is the metering valve? Is that just for powered discs?
Re: In need pics of 71 cuda brake/fuel routing pics [Re: roadrunninMark] #1127438
12/07/11 03:30 PM
12/07/11 03:30 PM
GA
GA
Are these the valves I should need for non powered disc front/drum back? Or should I just have the one Bob shows?
Re: In need pics of 71 cuda brake/fuel routing pics [Re: roadrunninMark] #1127439
12/07/11 04:18 PM
12/07/11 04:18 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Mark, I was just showing you that the dist block and prop valve how are made together.If you are changing to disc front you will need the metering one also. Don't be confused the metering block is a extra valve attached to the dist block.It is different then the prop valve. Early 70 E body w/disc had all 3 but after Jan 70 went to the 2 put together.
Hope this helps
Bob
Re: In need pics of 71 cuda brake/fuel routing pics [Re: roadrunninMark] #1127440
12/07/11 04:28 PM
12/07/11 04:28 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Check your email
