Late model trans pan rail # ID #1127192
12/04/11 01:42 PM
12/04/11 01:42 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline OP
JDMopar  Offline OP
I've tried Googling it every which way and can't find anything that makes sense! Can anybody tell me if this is a 4 or 5 spd automatic by this number?
265620025P52119448AE
That's the number on the pan rail on the drivers side. Any help appreciated.
Re: Late model trans pan rail # ID [Re: JDMopar] #1127193
12/04/11 09:56 PM
12/04/11 09:56 PM
JDMopar Offline OP
JDMopar  Offline OP
Re: Late model trans pan rail # ID [Re: JDMopar] #1127194
12/04/11 10:04 PM
12/04/11 10:04 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Are you sure you got the numbers right?
Couldn't find it here either
http://www.moparonlineparts.com/pdf/09-10%20REMAN.pdf
This is all I found: Durango 2007 RWD 5-45RFE
Re: Late model trans pan rail # ID [Re: jerseybud] #1127195
12/04/11 10:29 PM
12/04/11 10:29 PM
JDMopar Offline OP
JDMopar  Offline OP
I'm pretty sure I did. They look like little dots that shape numbers and letters instead of solid characters like old stampings. I'll check it again tomorrow to be sure.Do the numbers on the sticker mean any more then the stamped numbers? I know the top # on the sticker is the VIN #. It's supposed to be a 5 spd 545RFE from a 2007 Chrysler Aspen with a 5.7 Hemi. It looked like a Durango to me though. Thanks for checking it.
