Re: Automatic to 4 speed- Starter relays the same?
[Re: slowpoke]
#1127080
12/04/11 11:29 AM
12/04/11 11:29 AM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
I think there are 2 different relays. One for auto and a different one for manual.
Scott
1969 Super Bee, 383/4 speed
[Re: slowpoke]
#1127081
12/04/11 11:58 AM
12/04/11 11:58 AM
Posts: 75,095 A Banana Republic near you.
JohnRR
Changed my automatic to a four speed and it acts like the starter relay is bad (70 Bee) as the relay clicks and nothing happens w/ the starter. Looked online at NAPA and it lists two but no info for either. One has one spade and the other has two (like mine). Before I buy just wanted to make sure I have the correct one if there is a difference. (BTW brand new starter). Thanks in advance!
yes they are different , but depends on the year , 69 down had 2 seperate relay , one spade is connected to the case , you can just take a wire and connect it to the terminal you took the wire from the neutral safety switch , lower right looking at it and tie it to one of the bolts holding it to the firewall.
Not sure what year saw the clutch safety switch so after a certian year the both used the same relay .
[Re: slowpoke]
#1127083
12/04/11 01:33 PM
12/04/11 01:33 PM
Posts: 21,509 It's a dry heat
gtx6970
It's a dry heat
For 1970 and later, the relays are the same regardless of transmission S102 in the picture. S101 is manual trans 1969 back to approx 1966 depending on application
[Re: JohnRR]
#1127085
12/08/11 03:09 PM
12/08/11 03:09 PM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
What he said...
