spark plug questions #1126997
12/04/11 12:28 AM
12/04/11 12:28 AM
california
hornetnut Offline OP
california
ok,,, so i have a small problem with one tube being in the way, they are eddy performer rpm angle plug heads, does anyone have the part number for a shorter plug? the plugs are 3/4 reach 5/8 heads... thanks for any info...
Re: spark plug questions [Re: hornetnut] #1126998
12/04/11 02:35 PM
12/04/11 02:35 PM
california
california
i was hoping for an over the counter plug that i could get locally... ive heard that accels dont last long and my plugs are not easy to change, i put the 440 in my amc hornet so space is very limited
Re: spark plug questions [Re: hornetnut] #1126999
12/04/11 03:13 PM
12/04/11 03:13 PM
Alaska
73rrak Offline
73rrak  Offline
Alaska
Can you ding the tube a little bit to make room for the plug ? I've heard of people using lawn mower size plugs when they have this problem. I think one of the plug manufacturers make short plugs for this problem. Hopefully somebody with more info on the short plugs will chime in.
Re: spark plug questions [Re: hornetnut] #1127000
12/04/11 03:34 PM
12/04/11 03:34 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
you can try these - Autolite 2974. they're what's called a shorty and will work in a 440. Accel shorty's are fine too but try and find them!
Re: spark plug questions [Re: mikemee1331] #1127001
12/04/11 08:15 PM
12/04/11 08:15 PM
california
california
i looked at the autolites and they are the same length as the champions... and the lawnmower plug is a 3/8 thread length and 13/16 socket size.. i am at my wits end.... i may have to ding the header but i really dont want to..
Re: spark plug questions [Re: hornetnut] #1127002
12/04/11 10:11 PM
12/04/11 10:11 PM
Mississippi
bcr Offline
bcr  Offline
Mississippi
If and thats a big if you can find an old time parts man that still has catalogs plus know how to read them, I did say if didntI? Champion, Autolite and most all manuf. had index, cross reference charts, and a chart that shows their product by hex size, thread size,length, heat range a complete breakdown in back of the application catalog. A valuable tool if you can find them.
Re: spark plug questions [Re: hornetnut] #1127003
12/05/11 11:25 AM
12/05/11 11:25 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Ask this in the race forum , you may get the answer there .
Re: spark plug questions [Re: JohnRR] #1127004
12/05/11 11:54 AM
12/05/11 11:54 AM
dogdays Offline
dogdays  Offline
The three most dangerous words..."I have heard".
Nothing wrong with Accel plugs, many many users here and elsewhere. I believe they are made by NGK.
R.
Re: spark plug questions [Re: dogdays] #1127005
12/05/11 01:39 PM
12/05/11 01:39 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
I use the Accel with my angle plug BB Eddy's and have had no trouble.
Just ask for the Accel shorty equivalent. I do put an insulating sock on the spark plug boot head because it is quite close, but it is still a lot roomier than the Champion.
