Small Block Indy Heads #1126651
12/03/11 12:44 PM
12/03/11 12:44 PM
Canada
Max Weg Offline OP
Max Weg  Offline OP
Canada
Can W5 rocker gear be used in Indy 360-1 heads?
Max Weg
Re: Small Block Indy Heads [Re: Max Weg] #1126652
12/04/11 01:32 PM
12/04/11 01:32 PM
Canada
Max Weg Offline OP
Max Weg  Offline OP
Canada
I am surprised that I haven't received any info, someone must know.
Re: Small Block Indy Heads [Re: Max Weg] #1126653
12/04/11 02:00 PM
12/04/11 02:00 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
the indy 360-1 uses the same rocker as the 440-1 (with different shafts,spacers and hold downs) with the push rods up in the cover rail and a .800 0ffset on the intake. I think the w5 head has a different layout, less offset, shorter rocker but I have not run w5's
http://i1122.photobucket.com/albums/l529/sparky5r/DSCN0536.jpg
"Just a Bracket car dressed up like a streetcar"
Re: Small Block Indy Heads [Re: Just-a-dart] #1126654
12/04/11 02:17 PM
12/04/11 02:17 PM
Canada
Max Weg Offline OP
Max Weg  Offline OP
Canada
Thanks for the info much appreciated. Yes the W5 is .550" offset and appear shorter from your photo.
Max Weg
Re: Small Block Indy Heads [Re: Max Weg] #1126655
12/04/11 02:46 PM
12/04/11 02:46 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Glad to help
