Auto to 4Speed....will my driveshaft work? #1126636
12/03/11 11:48 AM
12/03/11 11:48 AM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
70 Bee changed over to a 4 speed. Trying to get finished up and am wondering about the driveshaft. Seems to fit correctly, but want to be sure I'm not missing something obvious. Will it be OK?
Thanks in advance!
Re: Auto to 4Speed....will my driveshaft work? [Re: slowpoke] #1126637
12/03/11 11:53 AM
12/03/11 11:53 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
It should be fine, 727 and 833 use the same slip yoke.
Re: Auto to 4Speed....will my driveshaft work? [Re: JDMopar] #1126638
12/03/11 12:05 PM
12/03/11 12:05 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Awesome...that's what I wanted to hear. Finally, something I WON'T have to buy!!
Thanks again!
Re: Auto to 4Speed....will my driveshaft work? [Re: slowpoke] #1126639
12/03/11 12:53 PM
12/03/11 12:53 PM
JDMopar Offline
JDMopar  Offline
At least that's one thing not to have to buy/replace! Just an FYI on something I recently learned....66-67 833 4 spds originally in A-body cars used the same slip yoke as a 904. Not a big deal, but could cause a little extra work and expense if someone did the same thing to an A-body as you did with your Bee.
Re: Auto to 4Speed....will my driveshaft work? [Re: JDMopar] #1126640
12/03/11 01:10 PM
12/03/11 01:10 PM
Alberta
rustbuckett68 Offline
Alberta
The aluminum 833 OD from a Volare/ Aspen /6 has the same yoke and DS lengh as a 904 from my 68 Valiant. Easy swap.
