Re: 3.9 block swap
[Re: savoy64]
#1126357
12/02/11 09:30 PM
12/02/11 09:30 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
you need to use the newer bolts, one of the long ones is a different length, they should all be the same thread. The 91 probably ain't got no where to put the crank sensor.
Re: 3.9 block swap
[Re: savoy64]
#1126359
12/02/11 10:01 PM
12/02/11 10:01 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
98s use a crank position sensor. it's what tells the engine when to fire the spark. all the MPFI magnum engines do (I don't know about the earlier TBI motors).
**Photobucket sucks**
