Re: what is the difference between a 68 and 69 RR hood?
[Re: DPelletier]
#1126165
12/04/11 11:14 PM
12/04/11 11:14 PM
Posts: 1,062 Amherst,NY
challengermike
Amherst,NY
On a related subject, is there a difference between the scoops and vents for a 69 hood with or without the air grabber set up? I picked up some this summer in a deal and noticed there was a difference in the screen pattern. Not being fluent in RR's I never thought of that detail. I did make sure she got the set for her 68 though.
yes and no , the scoops are the same, no air grabber has a ribbed solid block off plate ... for it's pleasure ... air grabber has a screen .
Arn't all the '69 hood vent screens (ram air) painted red from the factory? I seam to remember this when I was into RR's.
Ahhh; the red vs. black air grabber screen debate again......hang on, I need to grab a beer.
...OK, I'm ready now.
My 69 GTX had the block off plates that were black,is that may be why some people were confused?
[Re: challengermike]
#1126166
12/05/11 01:20 AM
12/05/11 01:20 AM
Posts: 8,403 Highland, MI.
Sunroofcuda
Highland, MI.
Q: Re: what is the difference between a 68 and 69 RR hood?
A: Only one year.
(Sorry - had to say it. I've been tempted to since first reading the subject title a few days ago!)
[Re: topside]
#1126168
12/05/11 12:01 PM
12/05/11 12:01 PM
Posts: 21,528 N.E. OHIO, USA
A12
N.E. OHIO, USA
Yup, '68 "scoops" are solid, basically an appearance item. Many years ago, I bought an early (9/30/67 SPD) Roadrunner, and the guy had a '69 hood. We tried using the '69 hood on the car, but either the striker or secondary latch didn't line up with the '68 location. I used another '68 hood and it fit perfectly. The Air Grabber screens on my '69 St. Louis RRs were a red-orange, and a square basketweave. I'd never seen them in black until the post already referred to.
If that's the case then it is true that late model year '68 rr/GTX hoods did start to have the additional cutouts for the '69 Air Grabber. My '68 rr with a 402 (April 02, '68) SPD had cutouts on the underside of the hood (like the black hood images in the previous post) for the AG. The hood latch worked and was correct for a '68. So if it's true that the '68 hood latch is different than a '69 (I know it is) then Chrysler did start to change over just like the '70 bottom K-frame change on the later '69 models (ie., A12's have this '69/'70 type K-frame).
MikeR
