904 transmission question #112578
08/30/08 04:34 PM
08/30/08 04:34 PM
az
stage3 Offline OP
stage3  Offline OP
az
I have a 1980 Chrysler lebaron 2dr with 904 lockup converter trans. Trans has a fresh rebuild which includes a reman valve body and rebuilt convertor.
Everthing seems fine on 1-2-3 shifts but SOMETIMES at 35 mph when the convertor locks up it will shutter? Is this a bad convertor or another problem. Fluid is at the add pint line hot idling in neutral with type f valvoline fluid which I dont feel to be an issue. Any suggestions?
Thanks in advance!
Re: 904 transmission question [Re: stage3] #112579
08/30/08 05:31 PM
08/30/08 05:31 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
change the fluid to type 4
Tony
70 AARCuda Vitamin C
Re: 904 transmission question [Re: stage3] #112580
08/30/08 06:34 PM
08/30/08 06:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Type F is the one fluid you do not want to use with a lockup converter.
