Page 9 of 10 1 2 7 8 9 10
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125435
07/24/12 08:55 PM
07/24/12 08:55 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Hurst pro-matic ratchet shiter in place.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125436
07/24/12 09:07 PM
07/24/12 09:07 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Why didnt you stay with the OD833?
I am truckless..
Re: Junkyard D150 Progress [Re: 340SHORTY] #1125437
07/24/12 10:44 PM
07/24/12 10:44 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
600 hp and 620 ft lbs of torque.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125438
07/24/12 11:04 PM
07/24/12 11:04 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I'm afraid That motor would shread OD. Dave
Re: Junkyard D150 Progress [Re: quickd100] #1125439
11/17/12 01:33 AM
11/17/12 01:33 AM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Inside pix
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125440
11/17/12 01:36 AM
11/17/12 01:36 AM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
quickd100 welded up some 3" header pipes from the block huggers for me.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125441
11/17/12 01:38 AM
11/17/12 01:38 AM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Texas Driveshaft hooked me up with an unbreakable shaft.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125442
11/21/12 05:10 PM
11/21/12 05:10 PM
Jasper Indiana
BIGMIKE@RIDETECH Offline
Jasper Indiana
Looking good!
Re: Junkyard D150 Progress [Re: BIGMIKE@RIDETECH] #1125443
01/15/13 01:56 AM
01/15/13 01:56 AM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Well, I found a new 1985 takeoff box close to where my son lives, so I am off to pick it up in a few days. It was on the truck for a few months and in dry storage for 26 years; the bumps and scratches are from moving it around.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125444
01/20/13 07:08 PM
01/20/13 07:08 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Just got back from picking up the box. Trim is missing; that's OK because all of it was coming off anyway. Fought some bad crosswinds/gusts coming back but the box stayed put; not the fuel guage though. It's dirty and has a few scratches but it is rust free and still wearing the grey paint in the bed.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125445
01/20/13 07:10 PM
01/20/13 07:10 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Pass side and inside
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125446
01/20/13 07:11 PM
01/20/13 07:11 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
And a pix of the driver's side
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125447
01/21/13 10:23 AM
01/21/13 10:23 AM
scratchnfotraction Offline
swwweeeettt!!! looks good.
looks cold as well.
Re: Junkyard D150 Progress [Re: scratchnfotraction] #1125448
01/21/13 11:34 AM
01/21/13 11:34 AM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Mike, the temp this morning is -21 below....BTW do you know what an 8 foot box weighs without the tailgate?
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125449
01/21/13 01:21 PM
01/21/13 01:21 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Why did you go with the short shifter instead of the longer handle pickup style?
Re: Junkyard D150 Progress [Re: stumpy] #1125450
01/21/13 03:22 PM
01/21/13 03:22 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Believe it or not I didn't know they made a longer model for the pickup until after I installed mine. I actually had to reverse the handle so it would clear the bench seat....
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125451
01/22/13 10:05 AM
01/22/13 10:05 AM
now thats real cold.
I dont know right off what one weighes,but it is kind heavy with 2 people lifting by hand.
I am scraping the hurst crapola shifter on mine,been notheing but a headache trying to get it to shift right.
I have been using the colum shifter in everything mopar for yrs so I know how it works and can shift it myself. mechanical linkage is the way I should have set it up in the first place and that 200 bux would have been beetr used esle where.
Re: Junkyard D150 Progress [Re: scratchnfotraction] #1125452
01/22/13 01:14 PM
01/22/13 01:14 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
It should be interesting as when I shifted it to move it back and forth in the garage it didn't want to go unless I played with the shifter. I wonder if Hurst is aware of these problems and maybe have a different length lever?
Mike, I was going to call up a few friends; but at -15 degrees they might not be my friends anymore. Hooked up some small tie-down straps to the stake pockets and used my engine cherry picker to off load it from the trailer. I plan on setting it on the truck in the next 2 days. I lifted one end and I think it would be a breeze with 4 people.
Re: Junkyard D150 Progress [Re: Hemi_Ram] #1125453
01/22/13 01:47 PM
01/22/13 01:47 PM
I have done it with straps and cherry picker/swing set
I agree 4 people are ideal to lift it.
Re: Junkyard D150 Progress [Re: scratchnfotraction] #1125454
03/20/13 01:23 AM
03/20/13 01:23 AM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Installed the bed, fuel cell, plumbed the fuel lines, installed a trans cooler and replaced the rusted wheels/worn out tires with a set of US Wheels chrome 8 spokes and 225/75/15 wrangler front tires. Will probably install a set of 265/70/15s on the rear to at least drive it until I tub it with 315/60/15s ET streets. A little at a time as the CC is burning. LOL
