Gotta have more gap... #1125152
12/01/11 06:16 PM
12/01/11 06:16 PM
SeventySatellite Offline OP
At the top of door where it meets the cowl... I need to widen the gap a bit but I don't know what I'm doing wrong. My last attempt I loosened all the bolts and then wedged a couple of stir sticks in there keep the gap but that still didn't work.
Re: Gotta have more gap... [Re: SeventySatellite] #1125153
12/01/11 06:27 PM
12/01/11 06:27 PM
NJ
70_FJ6_RR Offline
70_FJ6_RR  Offline
NJ
Is it an original door or aftermarket? Are the hinges original? It should line up with + or - gap width. You may need to shim the body side of hinge or drill the hinge to door holes a tad. If orig parts, it should line up. If they're repops, goodluck.
Re: Gotta have more gap... [Re: 70_FJ6_RR] #1125154
12/01/11 06:39 PM
12/01/11 06:39 PM
It's all original but I don't remember what the gap was like before I started taking the car apart years ago.
Re: Gotta have more gap... [Re: SeventySatellite] #1125155
12/02/11 01:18 AM
12/02/11 01:18 AM
NJ
70_FJ6_RR Offline
70_FJ6_RR  Offline
NJ
If you pull the fender off, it would be easier. Line up the bottom front of the door to the rocker front edge, then the top front of the door to the cowl and the rear to quarter height, with a 3/16" gap at the top front and the rear quarter edges, then snug the bolts. Also loosen the striker to line up the rear of the door. You can spend 5 mins to 5 hours to get doors perfect. Take your time! This pic is the only one I could find showing the fender to cowl gap. I spent quite a few hours line'n up the doors on this on! It's always a bad spot on these cars cause of the lead seam.
Re: Gotta have more gap... [Re: SeventySatellite] #1125156
12/02/11 02:00 AM
12/02/11 02:00 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Theres plenty of adjustment in the hinges, as the threaded bolt plates onside the doors allow it. I like to use 3/16" paint sticks as a guage. Unfortunately, some of our cars will never have perfect, uniform gaps without welding and or grinding edges.
Re: Gotta have more gap... [Re: SeventySatellite] #1125157
12/02/11 04:42 PM
12/02/11 04:42 PM
USA
b54406barrel Offline
USA
Based on what I see there, I'd pull the fender in a little & then see what your hood gap does, then bring the door out a little. This won't go over big here but back when I repaired these when they were new, Chrysler products had some of the worst 'gap issues' of the big 3. Typical is my 6bbl car, door aligned perfect but when the rocker was formed, it was crooked. You can put your pinky in at the back of the bottom edge & your thumb at the front! I almost sectioned it when I last repainted it but figured hey, it's stock!
Re: Gotta have more gap... [Re: b54406barrel] #1125158
12/02/11 11:30 PM
12/02/11 11:30 PM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
....... This won't go over big here but back when I repaired these when they were new, Chrysler products had some of the worst 'gap issues' of the big 3.........
X20
That is one of the biggest trouble spots on B-body panel alignment. It would help if both panels were the exact same width in that area.
Re: Gotta have more gap... [Re: 70_FJ6_RR] #1125159
12/29/11 12:30 AM
12/29/11 12:30 AM
I went ahead and shimmed the body side and it's all good now.
Re: Gotta have more gap... [Re: SeventySatellite] #1125160
12/29/11 02:45 AM
12/29/11 02:45 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I too spent many nights on each door on my RoadRunner.
Try removing the inner splash shield in the fender so you can access the hinge bolts with the door closed.
Loosen em up, open the gap and lock it down thru the fender splash shield opening.
