Re: leafspring car goes 4.48@169 sheesh!
[Re: John Burdine]
#1124802
12/01/11 06:27 PM
12/01/11 06:27 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
While technically that is a "leaf spring" car, it's far from a stock suspention. As mentioned the FAST guys are in the 9's w/ SS Springs.
would you rather see more 4 bar mustangs?
nope just an observaton. I'm guessing that if I had the MONEY to put together a 600ci motor w/ a big butt turbo that runs on alky I could make a Mopar do just as well.
[Re: Mr.Yuck]
#1124806
12/01/11 10:57 PM
12/01/11 10:57 PM
Posts: 2,449 nc
earthmover
nc
[Re: joshking440]
#1124807
12/01/11 11:02 PM
12/01/11 11:02 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
And yuck, if you can do it, than prove it......
This is the direction drag racing is going and if mopar people don't get on board we will all be hanging out watching the same 200 cars go down the track till the folks that own them pass away.....
easy, buy that camaro for 25cents on the dollar and the thousands of hours they have testing and put a cuda body on it. if you feel bad about the chevy engine, build a mopar engine and stick it in there
and Josh, we are all routing for you to get there. looks like you need to lose alot of weight compared to that car
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Mr.Yuck]
#1124808
12/01/11 11:20 PM
12/01/11 11:20 PM
Posts: 1,404 Chesterfield Twp. Mi.
John Burdine
Josh If you want to sport me the money I'll be glad to do it.
Too late, Josh is spotting all his money to me, 622 Predator, alky injected, biggest crank driven Procharger or twins, its on! only problem since its my car and i'll be attempting to tune it, it would probably run closer to 5.48 instead of 4.48, but hey i'll try.
[Re: joshking440]
#1124809
12/02/11 12:09 AM
12/02/11 12:09 AM
Posts: 3,422 Toronto
mshred
Toronto
These have been the worst responses I have ever read.......
No torsion no care..... Who cares if it's torsion or coil over.... 4.68 seconds to the eight on a drag radial tire did you miss that part of the title
Cal tracs are way closer to stock suspension than any of the beloved ss/ah or NSS car, and it's not far from stock at all.... It's a mono leaf spring and a traction bar for god sake.
Fast cars are cool..... But this is not the same eague people.....
BINGO ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: John Burdine]
#1124812
12/02/11 05:15 AM
12/02/11 05:15 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Lets take a look at the O/P and "discuss" a few items. No beadlocks. Tires are screwed to rims; isn't that effectively the same thing? No antiroll bar. I would think one would fight the tuning of the Caltracs. Leaf springs. The weakness of leaf spring cars is the wrap-up of the front section - the Caltracs eliminate that, which makes it basicly a ladder bar at that time. Don't get me wrong - hats off to anybody running those numbers, period. I'm just tossing a little light on a few items that I haven't seen "lit". ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Randy..]
#1124817
12/02/11 07:10 AM
12/02/11 07:10 AM
Evil Spirit
Newport, Mi
I find it amusing the things some people think are "cutting edge". Not slamming John Calvert - he's done a LOT for suspensions - but a lot of the things that people think are new I saw done 40 years ago. For instance the split segment springs - with different front and rear segments - my uncle did that stuff 40+ years ago. Also used solid or box tubing instead of the front segment, and even more outside the box - would weld the front segments together down the sides, leaving the rear to provide the spring - all done to keep the front section from wrapping up, or wheelhop. Add a little adjustment into the front mount point and you have a pretty well working "leaf spring" car. Sometimes todays "cutting edge" isn't as sharp as it might appear. ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: Quicktree]
#1124818
12/02/11 10:20 AM
12/02/11 10:20 AM
Posts: 739 Florida
408Dust
you put enough controllable HP to any kind of suspension you can go fast. I think the F.A.S.T. cars have proved that.
Best answer,good to see you still have gray matter.
[Re: joshking440]
#1124819
12/02/11 11:40 AM
12/02/11 11:40 AM
Posts: 12,417 Taxes & Virus's R-US, NY
Dragula
Not to pick, but this statement makes no sense in my area and probably many other areas. I think tracks run what brings in the money. Drag radial cars run at our track 1/mo and bracket cars we get a ton of and run twice a week. I don't see it catching on up here like it must be else where...So until they mandate us to run DR tires, bracket racing is what we do around here and we run slicks.
Heads up racing isn't real big here either. I love watching the DR stuff, but realistically, its not for guys on a budget. How is it you figure this is the future? We have heard this before from the FWD crowd, and those things are no where to be seen anymore.
I am sure if more Mopar people had the busget, we would run some classes like those, but not many of us do. Don't get me wrong, we love watching them and reading about them, but they are not cheap to build, and finding a local venue isn't easy either.
[Re: Dragula]
#1124820
12/02/11 03:10 PM
12/02/11 03:10 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
Those time are awesome. That car rocks & many other Chevy's out there doing it. Yes, we need more Mopar's out there doing this as well. We all know it cost more to build a Mopar. Josh, Get out there & kick some butt. 493JOHN, Get that Duster back out at Milan. Your build is further along than mine so you will probably beat me out there to take on all of these Chevy's & Mustangs we have in Drag Radial on those Friday nights.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
