84' LA 318 #1124393
11/30/11 11:20 AM
11/30/11 11:20 AM
Texas
Houstoner Offline OP
Texas
I've got a 1984 Dodge D150 with a 318 in it and I was curious what would be the best most affordable rout to go to squeeze some HP out of this engine. What I had in mind is to put a sock 340 cam in it with a four barrel intake/carb. What kind of heads should I run on it? Does what I have going so far a good start, and also how much HP can I get out of it from that I want to be around 300hp. Also if any knows what is the best transmission to run behind this engine?
Re: 84' LA 318 [Re: Houstoner] #1124394
11/30/11 11:30 AM
11/30/11 11:30 AM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
Re: 84' LA 318 [Re: Fat_Mike] #1124395
11/30/11 11:41 AM
11/30/11 11:41 AM
Kansas
racincuda Offline
racincuda  Offline
Kansas
My 318 combo was built using 340 heads w/2.02 valves, stock 360 cam, Edlebrock SP2P intake with a holley spread bore carb (great carb). If was to do it over I would pick a more agressive cam and maybe use small valve heads.
It got used with both Auto and a manual OD 4 spd trans, Iliked it best in my short wheel base 1/2 ton with th manual od and a few degrees advance on the cam timing
Re: 84' LA 318 [Re: Houstoner] #1124396
12/01/11 02:06 AM
12/01/11 02:06 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
If it was me, I would get a set of magnum heads for that 318. The thing is, you could probably call up LKQ and pick up a 360 magnum that could work with the proper flexplate. Already has the magnum heads and more inches too. Get a magnum style intake manifold and use your existing distributor and away you go. You'll have a hydraulic roller setup too. Cams are a little more expensive, but if the motor is good, you can reuse the lifters.
