vintage air sanden compressor moutning #1124317
11/30/11 12:15 AM
11/30/11 12:15 AM
Middleboro,MA
Jopar Offline OP
Jopar  Offline OP
Middleboro,MA
For what it worth... Here some shots of the sanden compressor install on a 440 using the Vintage Air kit. As you can see it is very tight...
Re: vintage air sanden compressor moutning [Re: Jopar] #1124318
11/30/11 12:16 AM
11/30/11 12:16 AM
Middleboro,MA
Jopar Offline OP
Jopar  Offline OP
Middleboro,MA
rear
Re: vintage air sanden compressor moutning [Re: Jopar] #1124319
11/30/11 12:17 AM
11/30/11 12:17 AM
Middleboro,MA
Jopar Offline OP
Jopar  Offline OP
Middleboro,MA
front
Re: vintage air sanden compressor moutning [Re: Jopar] #1124320
11/30/11 12:18 AM
11/30/11 12:18 AM
Middleboro,MA
Jopar Offline OP
Jopar  Offline OP
Middleboro,MA
power steering alignment
Re: vintage air sanden compressor moutning [Re: Jopar] #1124321
12/02/11 02:16 AM
12/02/11 02:16 AM
TC, Minnesota
Gabmando Offline
Gabmando  Offline
TC, Minnesota
AC and non AC cars have two different water pump housings. You can replace yours with one that has the thermostat housing slanted at an angle. I did on my 72 Charger 400CID when I added factory AC.
Re: vintage air sanden compressor moutning [Re: Gabmando] #1124322
12/02/11 11:08 AM
12/02/11 11:08 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
That is incorrect,most of the housings are the same with the exception of the Hemi and early housings .Some early A/C cars (but not all) used an angled thermostat housing depending on engine.
Also,Bouchillon's A/C mounting bracket will give you enough clearance to remove the thermostat housing bolt without removing the compressor.
Re: vintage air sanden compressor moutning [Re: Jopar] #1124323
12/02/11 11:30 AM
12/02/11 11:30 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
You could get a little clearance by putting the bolts in the opposite direction; the heads of the bolts are shorter than the nylock nuts......also you could space the brackets or.......
MikeR
Re: vintage air sanden compressor moutning [Re: Jopar] #1124324
12/02/11 11:40 AM
12/02/11 11:40 AM
pa.
dan9 Offline
dan9  Offline
pa.
I used a kit from classic auto air. I have an air grabber and have no clearence issues with my sanden. Maybe classic will sell you their brackets?
Re: vintage air sanden compressor moutning [Re: A12] #1124325
12/02/11 11:40 AM
12/02/11 11:40 AM
I was gonna suggest the aforementioned angled neck housing till I saw yours is an aftermarket alum one. I'd get a good NAPA superstat in there after checking it suspended in a pot of heated water/pushing the center valve on the pin back & forth to make sure it's free/drilling the 1/16" hole if it doesn't have one for easier fillup if desired & call it good. If everything stays high and tight you wont have to move the compressor or brackets to get at the stat housing bolts as it should be good for quite a spell
Re: vintage air sanden compressor moutning [Re: RapidRobert] #1124326
12/02/11 02:59 PM
12/02/11 02:59 PM
texas
magnum440 Offline
magnum440  Offline
texas
i installed vintage air setup on a small block and didnt care much for brackets and idler pulley setup,,for a bigblock i used ...http://bouchillonperformance.com/BPE4710.asp was tight also but everything lined up with o.e. pulleys and cleared shaker bubble
