Need help locating an article about BB manifolds #1124195
11/29/11 06:05 PM
11/29/11 06:05 PM
Arizona
PolyDart Offline OP
PolyDart  Offline OP
Arizona
Looking for the online article which was a shoot out among big block manifolds. The article compared single plane, dual plane, and tunnel ram manifolds.
One of the best in the group was the Weiand dual quad manifold. I'm curious as to what carbs they were running on that setup.
TIA
Re: Need help locating an article about BB manifolds [Re: PolyDart] #1124196
11/29/11 06:22 PM
11/29/11 06:22 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I have the article
They were running 2 Holley 750 DP's but never said if they were modded for the TR or not
Now I have the manifold and 2 750's except I need 1 Proform main body for a 4 corner idle DP
Re: Need help locating an article about BB manifolds [Re: PolyDart] #1124197
11/29/11 06:36 PM
11/29/11 06:36 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
i think it was called an intake shotout by name if that search name helps.edit:is this it?
http://www.google.com/url?q=http://www.m...esPyEcc6psKdJKA
Re: Need help locating an article about BB manifolds [Re: Clanton] #1124198
11/29/11 07:10 PM
11/29/11 07:10 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
not sure if this is the one you are looking for.
http://www.moparmusclemagazine.com/techarticles/mopp_0701_mopar_intake_manifold/index.html
sorry about that. same one listed above.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Need help locating an article about BB manifolds [Re: pittsburghracer] #1124199
11/29/11 08:14 PM
11/29/11 08:14 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I think this is the one he's looking for
Jeezzzzz, talk about jumping through hoops to find it
Was done by Hot Rod Engines
Part 1
http://www.hotrod.com/techarticles/hrdp_0712_mopar_intake_manifold_comparo/
Part 2
http://www.hotrod.com/techarticles/hrdp_0801_mopar_intake_manifolds/
Enjoy
Re: Need help locating an article about BB manifolds [Re: roadhazard] #1124200
11/29/11 09:21 PM
11/29/11 09:21 PM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Another good manifold shootout featuring 4150/Dominator/Dual Quad tunnel ram :
http://www.moparmusclemagazine.com/techa...st/viewall.html
Some dyno testing by Dwayne in the Moparts archives :
http://www.moparts.org/Tech/Archive/bb/8.html
Ron
Re: Need help locating an article about BB manifolds [Re: roadhazard] #1124201
11/29/11 09:45 PM
11/29/11 09:45 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
that was good reading
Re: Need help locating an article about BB manifolds [Re: roadhazard] #1124202
11/29/11 10:41 PM
11/29/11 10:41 PM
Arizona
PolyDart Offline OP
PolyDart  Offline OP
Arizona
Yes, those were the articles. Thanks for pulling them up.
I'm reading through the other pages as well. Thanks for the help
