Factory cam specs for 1967 gtx 440 HP Motor #1124167
11/29/11 05:48 PM
11/29/11 05:48 PM
massachusetts
P
Provan Offline OP
Provan  Offline OP
P
massachusetts
Can anyone get me the cam specs for the factory cam that came in the 67 gtx 440 hp motor..Thanks
76 DODGE VAN PRO STREET 67 DODGE CORONET R/T 480 STROKER
Re: Factory cam specs for 1967 gtx 440 HP Motor [Re: Provan] #1124168
11/29/11 06:27 PM
11/29/11 06:27 PM
Arizona
az426john Offline
az426john  Offline
Arizona
Short answer:
Intake Duration: 268 Degrees
Exhaust Duration: 284 Degrees
Overlap: 46 Degrees
Lift:
Intake: .458
Exhaust: .458
Data from Data sheet on Mopar Performance Cam P4452783 (replacement for stock cam)
Duration: 268/284 Degrees
Duration @0.050 228/241 degrees
Overlap: 46 Degrees
Center line: 115 Degrees
Lift:
Intake: 0.450"
Exhaust: 0.458"
Re: Factory cam specs for 1967 gtx 440 HP Motor [Re: az426john] #1124169
11/29/11 07:26 PM
11/29/11 07:26 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Stock duration was more like 214 & 220 at .050
Re: Factory cam specs for 1967 gtx 440 HP Motor [Re: Provan] #1124170
11/29/11 08:12 PM
11/29/11 08:12 PM
Could only find this in my 1967 "Glenns" manual. intake lift-.415" intake opens-19BTDC
Re: Factory cam specs for 1967 gtx 440 HP Motor [Re: RapidRobert] #1124171
11/29/11 09:12 PM
11/29/11 09:12 PM
It was MORE than enough for those bias ply tires!
No kidding...my first ride in a Mopar muscle car was a new 67 GTX 440 auto red with white interior
We were on the hwy doing about 50 MPH and when floored it smoked the tires like John Force and those tires were "singing" a few later we were almost Warp speed with the speedo sunk down around turn signal...
Ahhhhh.......That is what we all try and relive with these things--those kind of moments.
Re: Factory cam specs for 1967 gtx 440 HP Motor [Re: ] #1124172
11/29/11 09:23 PM
11/29/11 09:23 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
My 1970 Motors manual lists .450 lift intake and .465 lift exhaust for the 67 375 HP 440.
.425 and .435 for the standard 67 350hp 440
Re: Factory cam specs for 1967 gtx 440 HP Motor [Re: Sport440] #1124173
11/29/11 09:32 PM
11/29/11 09:32 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
My 68 MM says the same thing (.450/.465), but my service manual says .458. Service manual also says 268/284.
Re: Factory cam specs for 1967 gtx 440 HP Motor [Re: BSB67] #1124174
11/30/11 04:16 AM
11/30/11 04:16 AM
That is disturbing that alof of the published specs are different
Re: Factory cam specs for 1967 gtx 440 HP Motor [Re: RapidRobert] #1124175
11/30/11 02:06 PM
11/30/11 02:06 PM
dogdays Offline
dogdays  Offline
True, but even more disturbing is that fact that until recently ChryCo refused to give "duration at 50 lift" numbers AT ALL.
The written reason by one of my favorite whipping boys, Larry Shepard, translated to "You're too dumb to use 'duration at 50' and not confuse it with advrtised duration." This was implied, not stated directly. Boycott MOPAR cams!
There are dozens of better cams out there for almost any combination and use.
R.
Re: Factory cam specs for 1967 gtx 440 HP Motor [Re: dogdays] #1124176
12/01/11 12:52 PM
12/01/11 12:52 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
http://victorylibrary.com/mopar/mpcam-tech-c.htm
