Edelbrock STR 14-6 #1124037
11/29/11 02:49 PM
11/29/11 02:49 PM
Sweden
Mopar Guy Offline OP
Sweden
Is there anybody out there that have compaird the stock 440 six pack Edelbrock intake to the STR 14-6 in a dyno ? Id realy like to know if and what the difference whas in torque and hp in the lower rpm´s ?
Any help is greatly apriciated
Re: Edelbrock STR 14-6 [Re: Mopar Guy] #1124038
11/29/11 04:05 PM
11/29/11 04:05 PM
Cab_Burge Online work
Cab_Burge  Online Work
I haven't compared those two, I do know Paul Rossi and several other Super Stock 6 pak racers from back in the day, if that intake had been any good they would have used them in thier race cars. They didn't ( I'm sure they tested them ) If you want a better six pak intake look for the Weiand two piece mini tunnel ram six pak intake, all the SS racers used them BTW, there not legal in NHRA stock as they where not OEM from the factory IHTHs
Re: Edelbrock STR 14-6 [Re: Cab_Burge] #1124039
11/29/11 04:18 PM
11/29/11 04:18 PM
Sweden
Sweden
Im going to try to use this on the street in a stroker so thats why im trying to find out if it is a bad or good choise compaird to the stock intake !
Re: Edelbrock STR 14-6 [Re: Mopar Guy] #1124040
11/29/11 05:47 PM
11/29/11 05:47 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
I ran both many years ago on a fairly hot street car in those days. The STR is sort of a fuel distribution nightmare on the street. The stock intake was better at the track and on the street. If you want a bit more juice look to the Weiand as Cab said.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Edelbrock STR 14-6 [Re: sixpackbee] #1124041
11/29/11 05:49 PM
11/29/11 05:49 PM
Cincinnati OH
Bishop Offline
Bishop  Offline
Cincinnati OH
I hate to say Indy but you might want to look at there new Mod top intake
Re: Edelbrock STR 14-6 [Re: Mopar Guy] #1124042
11/29/11 06:06 PM
11/29/11 06:06 PM
I ran the stock type Edlbrcok low deck six pak intake on my 512 and 518 pump gas street and strip stroker. It went a best of 10.34 at 128.+mph on Oregon pump gas with the mufflers and air cleaner on I had a Weiand two piece for a 440 block but ended up selling it to another member on here because the stock Edlbrock intakes work so well I have a 464 440 block pump gas stroker motor with the stock Edlbrock six pak intake also that I used on the street and strip, they work really well
Re: Edelbrock STR 14-6 [Re: Bishop] #1124043
11/29/11 06:07 PM
11/29/11 06:07 PM
Sweden
Sweden
Id realy like to find a Weiand intake but that tuff to find ! Direct Connection had some modifications in there race manuals for the 14-6 that might help me !? There´s a pic of that included in this reply.
Re: Edelbrock STR 14-6 [Re: Mopar Guy] #1124044
11/29/11 07:55 PM
11/29/11 07:55 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I run a STR-14 intake with 2 650 Holley DP and it was faster than a TM-7 or M1 intake I run the same 1150 on both of them intakes. The STR-14 worked just as good on the street as the other 2 as well.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Edelbrock STR 14-6 [Re: MRMOPAR622] #1124045
11/30/11 12:18 PM
11/30/11 12:18 PM
Sweden
Sweden
I gues that one of the biggest mistake on this intake is that the carbs are placed to close to the the lid so i need to put a 1" spacer under the carbs to get it to work corekly and not run to ritch on fuel !
Re: Edelbrock STR 14-6 [Re: Mopar Guy] #1124046
11/30/11 12:19 PM
11/30/11 12:19 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
My STR-12 (small block cross ram) is faster and quicker than any other intake I've tried. The absolute same street manners too!
Re: Edelbrock STR 14-6 [Re: LAR_414] #1124047
11/30/11 12:43 PM
11/30/11 12:43 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
I had an STR crossram on the car too. The two four manifold has totally different characteristics than the Six Pack one. I too had no troubles with the cross ram. The three two's are not as friendly.
1959 Bugeye Sprite
1971 MG Midget
Re: Edelbrock STR 14-6 [Re: sixpackbee] #1124048
11/30/11 07:31 PM
11/30/11 07:31 PM
Loganville, GA
Stewart Offline
Stewart  Offline
Loganville, GA
Mopar Guy
Check your PM's
Re: Edelbrock STR 14-6 [Re: Mopar Guy] #1124049
12/03/11 04:58 PM
12/03/11 04:58 PM
San Diego
Redsled Offline
Redsled  Offline
San Diego
I run a 14-6 on my Coronet w/a 440. My manifold came with the mods that are in the MP Engine Book.I ran a stock setup also but w/ my setup the 14-6 works fine although it took some figureing out. It's been on the car for 4 years. I use mechanical carbs w/ 50cc pumps in the outboards. The motor has 10.7 cr w/ a small hyd.cam.My best 1/4 mile et is 11.03 @ 119.7, but I usually run 1/8 mile, and that best is 7.00 @ 98.2. I got the setup because I was told it would never work, and it looks cool.
Re: Edelbrock STR 14-6 [Re: Redsled] #1124050
12/04/11 04:39 PM
12/04/11 04:39 PM
Sweden
Sweden
Thanks for al feedback so far =) Im going to try to use the stock style of carbs ! Do you guy´s that vote for Weiand intake know if that intake would need any modification to work on the street ?
Re: Edelbrock STR 14-6 [Re: Mopar Guy] #1124051
12/06/11 12:56 PM
12/06/11 12:56 PM
Ransom Canyon, Texas
Madness Offline
Madness  Offline
I put this setup on my 474" low deck stroker, just for the street. I fabricated spacers to turn the AFB's east & west as Ma Mopar wanted them. Starts easily, idles cleanly forever at about 800 rpm. I did no modifications inside the manifold. Fabricating the throttle linkage was hardest part, but works great.
Re: Edelbrock STR 14-6 [Re: Mopar Guy] #1124052
12/06/11 11:37 PM
12/06/11 11:37 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
look up the mopar engine book it will tell you what to do for the weiand six pack
1.39 9.85 - 137 mph
Re: Edelbrock STR 14-6 [Re: Mopar Guy] #1124053
12/07/11 12:12 AM
12/07/11 12:12 AM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
I run the Weiand on the street. Works awesome. Lots of wow factor at car shows when u pop the hood.
Old Geezer Racing
