BB oil Pan gasket- who makes a good one? #1123773
11/28/11 10:39 PM
11/28/11 10:39 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline OP
VanishPt  Offline OP
V
Did a google search and founds a number of entrees dating back a ways.
What is the current opinon of a good gasket to use on a Charlies pan?
Re: BB oil Pan gasket- who makes a good one? [Re: VanishPt] #1123774
11/28/11 10:44 PM
11/28/11 10:44 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Muscle Motors has a real nice reusable rubber/metal gasket that I use. No leaks here.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: BB oil Pan gasket- who makes a good one? [Re: 71yelladustr] #1123775
11/29/11 02:41 AM
11/29/11 02:41 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
superformance
Re: BB oil Pan gasket- who makes a good one? [Re: VanishPt] #1123776
11/29/11 04:40 AM
11/29/11 04:40 AM
Cab_Burge Online work
Cab_Burge  Online Work
I liek and use the race Fel Pro, steel core rubber coated or siliconew coated. Not sure which I can get you a part number if you need it, there around $20.00 each or a little more from Summit, if I'm remembering correctly seal good and very reusable
Re: BB oil Pan gasket- who makes a good one? [Re: Cab_Burge] #1123777
11/29/11 08:55 AM
11/29/11 08:55 AM
V
VanishPt Offline OP
VanishPt  Offline OP
V
thanks. i saw a set of Flatout All Seasons that seemed to be rather industrial strength . For $50 , it should be. Anyone use them?
https://www.flatoutgroup.com/itemdetails.aspx?id=723
Re: BB oil Pan gasket- who makes a good one? [Re: VanishPt] #1123778
11/30/11 05:30 PM
11/30/11 05:30 PM
The Fel Pro part # for that good thick steel core oil pan gasket is Fel Pro # 1834
Re: BB oil Pan gasket- who makes a good one? [Re: Cab_Burge] #1123779
12/01/11 02:01 AM
12/01/11 02:01 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Good gaskets there..
Re: BB oil Pan gasket- who makes a good one? [Re: dodgeboy11] #1123780
12/01/11 09:21 AM
12/01/11 09:21 AM
V
VanishPt Offline OP
VanishPt  Offline OP
V
i think i will order one. Thanks.
Re: BB oil Pan gasket- who makes a good one? [Re: VanishPt] #1123781
12/01/11 11:14 AM
12/01/11 11:14 AM
Me too
Re: BB oil Pan gasket- who makes a good one? [Re: astjp2] #1123782
12/01/11 11:42 AM
12/01/11 11:42 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
superformance
X2 Good stuff
Re: BB oil Pan gasket- who makes a good one? [Re: 64dodge572] #1123783
12/01/11 08:38 PM
12/01/11 08:38 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
superformance
X2 Good stuff
X3 Great vendor and perfect fitting gaskets that perform as designed
Gus
64 Plymouth Savoy
Dana 60
