Re: What compression would you run with a 499 stroker?
[Re: challengermike]
#1123591
11/28/11 08:08 PM
11/28/11 08:08 PM
RapidRobert
the good in your favor: alum heads and good quench (zero deck/.039" gaskets right?). First I'd find the stealths' cc's & valve relief CC's & plug it all into KB's calculator & post your SCR. WAG 10 ish. I'd much rather be a slight bit low on DCR & run an aggressive adv curve. EDIT that's 10 ish maybe that I would shoot for
[Re: dogdays]
#1123594
11/28/11 09:34 PM
11/28/11 09:34 PM
Posts: 12,194 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Just how high you can go depends on a lot of factors like; how loose is the converter, how fast does the timing come in, what gears are in the car, how heavy is the car, how long does it hold in each gear, how do you drive it, etc, etc.
My Cuda is 3,450lbs with 3.91s and a fairly loose converter. The engine is 499" with a cam similar to yours. I run 11:1 on pump swill. As long as I keep it 180* or so, it does fine.
Master, again and still
#1123595
11/28/11 09:57 PM
11/28/11 09:57 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Im not sure what to put into this spot
Intake Closing Point (degrees)ABDC @ 0.050 lift plus 15 degrees
My cam cam only shows this spec for valve timing @ .015, its 71 abdc
The compression (static) is just the volume... what really counts is the dynamic compression, thats when the intake closes(you dont make compression with the intake open) then its where is the piston in the cyl when the intake closes... but with the dynamic compression I would look at about 9.1 or so... static MIGHT be about 10.8 or so
[Re: BradH]
#1123597
11/28/11 11:00 PM
11/28/11 11:00 PM
Posts: 4,956 WI
Dcuda69
WI
It's a street car, right? Build it at 10.0 and don't worry about the next time the local pump gas octane drops another point (or 2) when the Feds screw around w/ fuel again. You'll have enough torque w/ the extra cubes that you'll never miss the additional CR.
Exactly what I did with my 470". It's at 10.2:1 and runs fine on anything I put in it!
#1123599
11/28/11 11:39 PM
11/28/11 11:39 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
There are several different DCR calculators that use different closing points (if that makes any sense). Your .015" and 71 ABDC intake closing is based on seat or advertised duration, asuming that your lash is set at .022", you have 1.5 rocker ratio, and the cam is installed at 106 ICL. Your .050" duration intake closing point is 52 ABDC, again, assuming a 106 ICL.
At 10.4, and 1000 ft above sea level, you'll be on the edge of dentonation, IMO.
[Re: BSB67]
#1123601
11/28/11 11:51 PM
11/28/11 11:51 PM
Posts: 1,062 Amherst,NY
challengermike
Amherst,NY
using the 52 @.050 that gives me
DYNAMIC EFFECTIVE COMPRESSION RATIO
8.511
STATIC COMPRESSION RATIO
9.773
#1123602
11/28/11 11:57 PM
11/28/11 11:57 PM
Posts: 7,664 IN
ahy
IN
I run 10.2 in an Ed headed 496 with 243@.050 cam. I figured I could push it a bit more to 10.4-10.6 but I like having a little margin in case of sustained hard running or so-so gas.
#1123603
11/29/11 12:03 AM
11/29/11 12:03 AM
Posts: 392 Mississippi
lahatte
Mississippi
You shouldn't use the .050 number for calculating Dynamic Compression Ratio. Air can still be pushed out of the combustion chamber through the .050" open valve, and thus, not compressed. The true DCR theoretically begins when the intake valve closes. Some cam specs will give an angle After BDC (.006 gap). I think that's a better number to use for calculating DCR because the valve is pretty nearly closed then.
