Re: Please help ID this brake booster (needs rebuild kit).
[Re: moparmarks]
#1123506
11/28/11 05:55 PM
11/28/11 05:55 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
That booster is available at most any auto parts store for $125 or less. BUT – if the car has been converted to discs do NOT use that drum-brake booster with them. It will feel OK for normal driving but will not provide enough assist for a panic stop. Discs require higher hyd pressure than drums, due to lack of servo action and . Other people might argue a drum booster is fine, but the factory engineers used different boosters between drum and disc, so contemplate why they did that. Maybe they knew a little more than most of us do. Anyway, a bad booster typically gives a HARD pedal, not a LOW pedal. If the pedal is low, something in the pedal-booster-MC geometry is amiss.
[Re: Jeremiah]
#1123510
11/29/11 12:32 PM
11/29/11 12:32 PM
Fury Fan
Indiana
Am I the only person to have this problem?
Nope, not by a long shot! I bet I've said the 'don't use a drum booster on discs' about 12 times in the last few years.
My problem, about 20 years ago, was installing a disc booster and MC with a manual pedal setup in a C-body. Super-soft pedal that felt spongy (despite weeks of every type of bleeding you can envision) yet stopped the car fabulously and with good modulation due to long pedal travel. No 'expert' anywhere figured it out, and I stumbled across the answer myself about 10 years afterward.
[Re: Fury Fan]
#1123513
11/29/11 10:20 PM
11/29/11 10:20 PM
Posts: 12,528 Western Colorado High Desert
moparmarks
Well thats some good info there. I was just going to do that on my 65 Satellite. Wanted to keep the original booster but want to use the 73-up A/E disc. Just had Ramman rebuild and replate the booster. Now I don't know what I will do. Probably round up a Bendix hemi style booster and have Wayne redo it. Don't what to use the big 71-up Midland Ross and don't think it will fit anyhow.
Also are the Midland Ross boosters from Rockauto zinc plated or painted black?
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
