Re: NSS Record Holder!!!!
[Re: n20mstr]
#1122972
12/12/11 11:33 PM
12/12/11 11:33 PM
Posts: 1,162 s e mich
ro23car
s e mich
im pretty sure nitrous was availible in the 60's....
ill google it up.
[Re: ro23car]
#1122973
12/12/11 11:46 PM
12/12/11 11:46 PM
Posts: 614 Michigan
Get-X
I'm pretty sure WWII aircraft used it for high altitude horsepower.
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: Get-X]
#1122974
12/12/11 11:57 PM
12/12/11 11:57 PM
ro23car
s e mich
ya just found that out on yb. they are pretty smart over there. how ya doin mark?
Re: Who has the Fastest NSS car!!!!
[Re: n20mstr]
#1122975
12/13/11 12:14 AM
12/13/11 12:14 AM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
Maybe you guys should re-think the trie sizes a little.,....
LOL 14 X 32 ????
Maybe you go a lil faster if you have less rotating weight back there.
This is 2011, people are going in the 7's and 6's on 9 and 10" tires
Oh yea thats right it Nostalgia Super Stock....supposed to be the 60's
Well I'm not as fast as those guys but I've always run a 9 x 28 tire. Look at all the Stockers that are flying with the 9 x 30 mandated tires too. I see no reason to drag around all that tire in high gear.
[Re: ro23car]
#1122976
12/13/11 12:14 AM
12/13/11 12:14 AM
Posts: 614 Michigan
Get-X
Doing good Bill, thanks. Just trying to clean my garage up and trying to find room for a new welder and a bigger compressor. Already 12 ibs of sh!t in a 6 lb bag in there ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: n20mstr]
#1122978
12/13/11 01:45 AM
12/13/11 01:45 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Hmmmmmm
NSS now thats from the 60's right??? Since when was a B1 looking head availible then??? These cars are supposed to look period correct RIGHT?! ![](/ubbthreads/images/graemlins/shruggy.gif)
NOW....SuperstockRacer has an 8 sec car....and it LOOKS THE PART UNDER THE HOOD....(No B1's)
NoJoke, you never met me, why you make comments like that towards me??? Im just stating facts here, SSR has an 8 sec car with Indy heads.
Tony,you want to stir the pot and include that NON-CONTENDER wanna-be,take it to the bullit,his name is not worthy of this thread or even this site.That way he can speak for himself and get put in his place. All his legacy does here is lock threads and Rob has a good one going on,so drop his name or take it to YB ![](/ubbthreads/images/graemlins/weld.gif)
[Re: hemi-itis]
#1122979
12/13/11 09:13 AM
12/13/11 09:13 AM
actionange
anywhere@ anytime
Hmmmmmm
Hey Al- shouldn't you be out in the garage working on your car??? It'll be spring before you know it... ![](/ubbthreads/images/graemlins/Santa3.gif)
[Re: Get-X]
#1122980
12/13/11 10:22 AM
12/13/11 10:22 AM
ro23car
s e mich
ya it gathers up fast lol. are you doin anything with your car?
[Re: ro23car]
#1122981
12/13/11 10:34 AM
12/13/11 10:34 AM
Are tunnelrams allowed in NSS racing? They were period correct right?
[Re: poppaj]
#1122982
12/13/11 10:38 AM
12/13/11 10:38 AM
Posts: 641 Bergen County NJ
NoJoke
Bergen County NJ
LOL 14 X 32 ????
Paul H tested 29.5, 31.0, 33.5 and was the quickest on the 29.5's
Casey what gear you guy run in your car? I have Mike Bookers old MW center section from his SS/AH cuda and they had 5.60 gears... I don't plan on buzzing the motor that high but I'm thinking a 4.88 might be a good starting point...
#1122983
12/13/11 06:10 PM
12/13/11 06:10 PM
actionange
anywhere@ anytime
Yes period correct but not in Super Stock. Tunnel rams belong in Nostalgia Pro Stock.
[Re: 383man]
#1122987
12/13/11 11:22 PM
12/13/11 11:22 PM
NoJoke
Bergen County NJ
My brother runs a tunnel ram on his low deck 499 in his 64. He is not happy with it as the top of the carbs come right to the bottom of this scoop. He plans to build an RB block eng and go to either the Indy box crossram or the standard Mopar crossram. I have to agree that the tunnel ram belongs more in Nostalgic Pro Stock more then NSS. Most NSS rules say you have to run 2 fours if thats what they used back then and you can use a tunnel ram as long as its 2 fours. But in my opinion when you look at my brothers 64 with this large hemi scoop and 2 fours on the tunnel ram and then compare it to my 63 with the right size Maxie scoop and one carb my 63 looks way more period correct with the hoods closed. I mean the fans see them race with the hoods closed and do these newer taller versions of the hemi and max wedge scoops look more correct then a single carb car with the normal size scoop ? Not knocing the newer taller scoops its just alot of NSS clubs wont let me run with a single carb as you have to have 2 carbs for my 63 to be legal. But I feel with the hood down my 63 looks more correct then cars with the taller scoops so they can fit 2 carbs with different intakes. And dont get me wrong as I am not complaining as I could not run many NSS races even if I was all legal by the rules. I am just making an observation that the fans cant see how many carbs are under the hood when they are racing with the hoods down. But they can see the bigger scoops that are not correct looking. And I do understand that the bigger engines most use now need alot more air also. Just an observation that I was curious what anyone else might think. Ron
The carbs being to close to the scoop is a problem for sure you can loose power because of that and volocity... Thats the same scoop I have on my car and to be honest that scoop any taller looks like S**T if you ask me you better putting a pro stock scoop on that car at that point... If you brother changes his intake to one of those indy bath tub set ups he going to loose power.. I had a low deck 512 with a indy single carb and it ran unreal. I had a Indy Tunnel ram with 2 4's that I never put on because the car was running so consistant that I didnt want to mess with it but the tunnel ram with 2 4's was good for another 60hp easy.... If he can drop that motor a half and inch and get a little more clearance for is carbs hes better off... Id hate to see him loose power... Just my ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: actionange]
#1122988
12/13/11 11:27 PM
12/13/11 11:27 PM
NoJoke
Bergen County NJ
Ang what do you think is this intake legal for NSS?
![](http://i50.photobucket.com/albums/f348/rob7187/426%20SS%20Hemi/DSC02585.jpg)
![](http://i50.photobucket.com/albums/f348/rob7187/426%20SS%20Hemi/DSC02435.jpg)
[Re: 383man]
#1122990
12/14/11 09:42 AM
12/14/11 09:42 AM
NoJoke
Bergen County NJ
Actually my brother is going to build a complete new eng using a RB block as the 499 in it now is a low deck B block. He wants to build a much stronger eng with the RB block and Victor heads as he has RPM heads on the 499 in it now. And then maybe use the Indy box style crossram.
As far as I know any 2 four intake is legal for NSS acording to the way the rules read I believe ? Ron
I'm sorry Ron I mis read what you wrote about the intake... Is he going to use a mega block for his new build?
[Re: NoJoke]
#1122991
12/14/11 09:56 AM
12/14/11 09:56 AM
actionange
anywhere@ anytime
My thoughts and what is ultimately deemed legal are 2 different things. It appears that each NSS organization has different interpretation of what is and isn't allowed. That would in my opinion be legal only on 68 Darts and Cuda's- but other cars that run in NSS emulating current Super Stockers (in the SS/AA and upper classes might be using these). The "Honkin' Hemi 65 Plymouth comes to mind. Ultimately it all comes down to bracket racing after class run offs. ![](/ubbthreads/images/graemlins/Twocents.gif) Groups I run with here on the East coast would allow that on an A/FX classified car.
