6-Pack Intake Air/Fuel Distribution #1122809
11/28/11 01:22 AM
11/28/11 01:22 AM
Chicago
PurpleBeeper Offline OP
Chicago
I saw a couple guys mention that stock 440 six pack intakes have fuel distribution problems on cylinders 6/7. Is this true? Has anyone worked out a modification to fix this? I want to run a 250 nitrous shot using a NOS plate system. Thanks!
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 6-Pack Intake Air/Fuel Distribution [Re: PurpleBeeper] #1122810
11/28/11 10:37 PM
11/28/11 10:37 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
#4 is the problem. Run a higher ratio rocker on #4 intake or a custom cam.Or less compression
Mine has broken plugs and dished a piston from detonation in #4.
Was`nt a problem footbraking,a 2-step killed it in 4 passes.
Going to a 4-speed took 80 passes.
Never messed with NOS,but I assume same problems if you push the cyl pressures.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
