Hedman Headers leak like crazy!!!!! #112268
08/29/08 09:23 PM
08/29/08 09:23 PM
san diego, ca
dakrt23 Offline OP
dakrt23  Offline OP
san diego, ca
So i finally got my 360 dart running and everything is working perfectly, the car is awesome, except these damn headers will not seal... i have taken it to two different exhaust shops, one that switched my cheesy bolts to studs and better gaskets and they still leak LOUDLY, like i can hear it over dumped spintech pro-street mufflers... thats bad...
both places told me the flanges are just too weak to provide any flat mating surface... looked it up on summits site and they have a 1/4" flange vs. 5/16" for everyone else...
the question is... is there anyway to get these hedmans to seal up without cutting off this flange and welding on a newer thicker one, or switching headers?... if there isnt, then ill end up biting the bullet and switching, but if anyone has any tips or tricks with these headers in particular, let me know!... thanks...
Re: Hedman Headers leak like crazy!!!!! [Re: dakrt23] #112269
08/29/08 09:33 PM
08/29/08 09:33 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Use Ultra-Seal gaskets, and a film of copper silicone on both sides. My old set of Hedmans sealed right up using that method
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Hedman Headers leak like crazy!!!!! [Re: 69L78Nova] #112270
08/29/08 09:52 PM
08/29/08 09:52 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Are they new headers ? 1/4" is pretty good compared to header flanges years ago. Mine are Hedman that have been on my car for 2 years with zero problems and I just use standard gaskets. Ron
Re: Hedman Headers leak like crazy!!!!! [Re: 69L78Nova] #112271
08/29/08 10:02 PM
08/29/08 10:02 PM
san diego, ca
dakrt23 Offline OP
dakrt23  Offline OP
san diego, ca
cool, thanks ill give that a try!!!... using standard paper gaskets now, definitely going to try a steel core gasket next... never liked paper ones, they just came with the headers...
Re: Hedman Headers leak like crazy!!!!! [Re: 383man] #112272
08/29/08 10:04 PM
08/29/08 10:04 PM
san diego, ca
dakrt23 Offline OP
dakrt23  Offline OP
san diego, ca
after looking around summits site, all the other headers (Even summits generic ones) had 5/16" flanges... hedmans were the weakest at 1/4"... seems to be hit and miss with these things... a friend has a set of hedmans on his 67 cuda and they are fine... mine sound horrrrrrible... its all i can hear and it makes driving the car not fun...
Re: Hedman Headers leak like crazy!!!!! [Re: dakrt23] #112273
08/29/08 10:10 PM
08/29/08 10:10 PM
ky.
K
kenworth_goose Offline
K
ky.
If you take those paper gaskets and soak them overnight in water, install them wet, they won't leak anymore.
Re: Hedman Headers leak like crazy!!!!! [Re: dakrt23] #112274
08/29/08 10:10 PM
08/29/08 10:10 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Do your heads have the air injection holes on the floor of the ports, & if so, did you plug them?
Re: Hedman Headers leak like crazy!!!!! [Re: dakrt23] #112275
08/29/08 10:14 PM
08/29/08 10:14 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Do a search for REMFLEX gaskets. The best choice for a thin or warped to s header.
Re: Hedman Headers leak like crazy!!!!! [Re: Y3 70 BEE] #112276
08/29/08 11:18 PM
08/29/08 11:18 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Best darn gaskets I've ever tried! www.remflex.com
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Hedman Headers leak like crazy!!!!! [Re: kenworth_goose] #112277
08/29/08 11:48 PM
08/29/08 11:48 PM
san diego, ca
dakrt23 Offline OP
dakrt23  Offline OP
san diego, ca
ive heard that trick too, thanks for the input... ill probably just end up trying some steel core gaskets or these remflex ones everyone is suggesting...
Re: Hedman Headers leak like crazy!!!!! [Re: vdriver] #112278
08/29/08 11:50 PM
08/29/08 11:50 PM
san diego, ca
dakrt23 Offline OP
dakrt23  Offline OP
san diego, ca
pretty sure there are no air injection ports... i didnt see anything unusual when i was painting the heads.. are they located just below the exhaust ports?...
Re: Hedman Headers leak like crazy!!!!! [Re: Y3 70 BEE] #112279
08/29/08 11:51 PM
08/29/08 11:51 PM
san diego, ca
dakrt23 Offline OP
dakrt23  Offline OP
san diego, ca
just checked those out, they have some pretty strong claims... no leaks, no retorquing (thats hard to believe)... pretty pricy for gaskets but if they work they will be worth it... have they worked for you as advertised?...
Re: Hedman Headers leak like crazy!!!!! [Re: Junky] #112280
08/29/08 11:52 PM
08/29/08 11:52 PM
san diego, ca
dakrt23 Offline OP
dakrt23  Offline OP
san diego, ca
have they worked for you as advertised?... they have some big claims to go with the big price... what do you think?... thanks for the help...
Re: Hedman Headers leak like crazy!!!!! [Re: kenworth_goose] #112281
08/29/08 11:55 PM
08/29/08 11:55 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I've heard of that...but..I think it depends on whose gaskets.....one fellow I know used a brand X gasket and they were pretty well mush when he went to get them in the morning after an overnight soak!!
A good felpro 1414 for a big block and some Ultra-Copper RTV and you'll usually be good to go for a long time.
Give the bolts a nudge after about 10 runs or so.
Re: Hedman Headers leak like crazy!!!!! [Re: dakrt23] #112282
08/30/08 12:02 AM
08/30/08 12:02 AM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
I sealed up some c body cast manifolds that no ultra seal or anything else would seal. When you see how beefy remflex are you will see why.
Re: Hedman Headers leak like crazy!!!!! [Re: Y3 70 BEE] #112283
08/30/08 01:15 AM
08/30/08 01:15 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've been hearing good things about remflex for years, but never did try them. It is quite a bit for exhaust gaskets, but if they work, well worth the money IMO.
Re: Hedman Headers leak like crazy!!!!! [Re: dakrt23] #112284
08/30/08 02:45 AM
08/30/08 02:45 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
If your heads have these holes, and they ain't plugged, you're wasting your time with different gaskets/headers/whatever. You gotta plug 'em.:
Re: Hedman Headers leak like crazy!!!!! [Re: vdriver] #112285
08/30/08 03:19 AM
08/30/08 03:19 AM
delivering your oil
nutso suave Online content
nutso suave  Online Content
delivering your oil
an old hot rodder told me a good way to prevent header leaks is to cut the plate between the tubes, so that each tube is bolted individually. he uses those thick felpro gaskets and doesn't have a problem with leaks.
Re: Hedman Headers leak like crazy!!!!! [Re: vdriver] #112286
08/30/08 04:25 AM
08/30/08 04:25 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
check... NOW!
Re: Hedman Headers leak like crazy!!!!! [Re: nutso suave] #112287
08/30/08 06:52 AM
08/30/08 06:52 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
This is good advice right here. And make sure the headers aren't hitting a head bolt on the bottom of the flange.
