Re: Steering coupler clamp [Re: Flite_727] #1122642
11/29/11 08:18 PM
11/29/11 08:18 PM
Retired now in Tennessee
Chi_Town_Runner Offline
Here's a portion of the TSB.
The steering shaft coupling cover is designed to provide for permanent protection against the escape
of lubricant and entry of water, dirt or other contaminants. It has been found that during any service to
the steering column, steering gear or instrument panel where the column is lowered or disturbed, the
coupling cover and seal may become loosened or dislodged. Once the cover has become loose, it is
difficult to get a tight seal or re-installation or replacement of the cover. A SERVICE COUPLING
COVER RETAINING CLAMP PART NUMBER 2996935 HAS BEEN RELEASED AND SHOULD BE
INSTALLED WHENEVER THE COLUMN OR GEAR HAS BEEN DISTURBED FOR ANY REASON
FYI.
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: Steering coupler clamp [Re: Chi_Town_Runner] #1122643
11/29/11 10:57 PM
11/29/11 10:57 PM
Ohio
JT01 Offline OP
JT01  Offline OP
Ohio
So is that a mopar part number and is it still avaliable?
Re: Steering coupler clamp [Re: JT01] #1122644
12/02/11 06:20 PM
12/02/11 06:20 PM
Ohio
JT01 Offline OP
JT01  Offline OP
Ohio
bump again
Re: Steering coupler clamp [Re: JT01] #1122645
12/02/11 06:40 PM
12/02/11 06:40 PM
Central CT
Craneman Offline
Craneman  Offline
Central CT
1967 F.A.S.T. Dodge Coronet R/T Survivor 528 c.i.d. 12.21 @ 116mph........ 1955 DeSoto Fireflite Coronado Hemi Survivor
Re: Steering coupler clamp [Re: Craneman] #1122646
12/02/11 07:02 PM
12/02/11 07:02 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
but thats not what we is looking for.
5549 post on old board
Re: Steering coupler clamp [Re: 05dakota] #1122647
12/02/11 08:10 PM
12/02/11 08:10 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
if you are rebuilding the coupler i would suggest looking into the re-build kit in the link i sent you waaaay up at the top (steer and gear). they have a boot that fits over the top of the coupler and keeps that pesky lid on. if you're just looking for the clip, get in line and it's a long line!
