Factory throttle cable hooked to a Dominator #1122131
11/26/11 11:31 PM
11/26/11 11:31 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
Hmmm, messing around tonight and looks like I might have to fab something up. How did you guys attached the cable to the carb (4500)? I would rather get rid of the cable and have a solid linkage, but will have to save that for another time.
Re: Factory throttle cable hooked to a Dominator [Re: Scamp451] #1122132
11/26/11 11:38 PM
11/26/11 11:38 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
if your cable has a clevis type end on the cable then just use a pin with a small clip, if you are talking mounting the cable to the carb then Jeg's has a nice mounting system, thats what I used on my dommy and it eliminated the mount on the manifold which you normally have to modify to work.
Re: Factory throttle cable hooked to a Dominator [Re: dartman366] #1122133
11/26/11 11:43 PM
11/26/11 11:43 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
Are you using a factory A body cable or a morse cable?
Re: Factory throttle cable hooked to a Dominator [Re: Scamp451] #1122134
11/27/11 01:22 AM
11/27/11 01:22 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Igot mine from jegs had to melt the cover off the cable for it to work
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Factory throttle cable hooked to a Dominator [Re: Scamp451] #1122135
11/27/11 01:49 AM
11/27/11 01:49 AM
AndyF Online content
AndyF  Online Content
Just buy a throttle bracket kit from Mancini or Hughes.
Re: Factory throttle cable hooked to a Dominator [Re: AndyF] #1122136
11/27/11 12:02 PM
11/27/11 12:02 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Jegs bracket and Lokar cable for me.
Re: Factory throttle cable hooked to a Dominator [Re: gsmopar] #1122137
11/27/11 12:20 PM
11/27/11 12:20 PM
ONTARIO,CANADA
604 Hemi GTX Offline
ONTARIO,CANADA
I used a throttle cable from an early 80's half ton with a straight six. The throttle bracket i used was the jegs throttle bracket
http://www.jegs.com/i/JEGS+Performance+Products/555/15239/10002/-1
Kevin
