Re: Vacuum Gauge Recommendations/Questions
[Re: dg_dodge]
#112171
08/29/08 08:29 PM
08/29/08 08:29 PM
RapidRobert
I use this one from Sears.The quality of their tools isn't what it used to be but this gauge works OK for me as I don't use that often. I usually hook to the choke pulloff nipple on the carb as it fits the gauge hose & it's a manifold source. For a permanent conection anywhere on the intake where you can easily add the fitting to connect it to the gauge hose is good including the PB hose & a manifold vacuum nipple on the carb.
