car won't warm up,no heater? #1120735
11/24/11 06:25 PM
11/24/11 06:25 PM
Seymour,IN.
HoosierGTX Offline OP
Seymour,IN.
I have a 88 Fifth Ave. that won't warm up,you can run it for hours and the temperature gauge never gets past the 1/4 mark,so I get no heat in the car.I just replaced the thermostat and coolant and it didn't help at all.Any suggestions will be appreciated,thanks guys.
Re: car won't warm up,no heater? [Re: HoosierGTX] #1120736
11/24/11 06:32 PM
11/24/11 06:32 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
you can't really go by the guage, it's just a indicator more or less. i'm gonna say you still have a thermostat issue. it's either stuck open or installed crooked (don't ask how i know about that).
Re: car won't warm up,no heater? [Re: HoosierGTX] #1120737
11/24/11 06:40 PM
11/24/11 06:40 PM
Get a new hotter stat and a candy thermometer at your grocery store & see what coolant temp you do have. Get the eng coolant temp squared away then back flush the heater core and a garden hose/spray nozzle will work just dont use full psi. Make sure the heater hoses are on the correct nipples and the heater controls are positioning the doors where they should be & same w the vacuum servos if used
Re: car won't warm up,no heater? [Re: HoosierGTX] #1120738
11/24/11 07:35 PM
11/24/11 07:35 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
dummy gauge maybe...Do you have the correct radiator cap on it? Perhaps you aren't building enough pressure to start cookin' the coolant. If your thermostat was stuck closed you would boil over the block because it won't cool down. If it was stuck open you would at least get a lower than normal hot temperature. Can you grab the radiator hose with your hand when its been running for 10 minutes?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: car won't warm up,no heater? [Re: HoosierGTX] #1120739
11/24/11 07:44 PM
11/24/11 07:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
1/4 scale should be enough to get heat, your heater core is probably plugged.... Disconnect the hoses & flush the heater core,,, A garden hose works well for this.... If you still get no heat try partially blocking the radiator with cardboard behind the grill..
Re: car won't warm up,no heater? [Re: 1_WILD_RT] #1120740
11/24/11 10:31 PM
11/24/11 10:31 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
If the heater core was plugged, wouldn't it run HOT??? In my experience, Mopars have always ran on the cool side according to the guage. Ae there other issues that you assume are related to your low temps???
Re: car won't warm up,no heater? [Re: Fat_Mike] #1120741
11/24/11 10:44 PM
11/24/11 10:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If the radiator were plugged it would run hot, the heater core is completely unimportant to cooling & if plugged coolant flow is un-effected..
Re: car won't warm up,no heater? [Re: 1_WILD_RT] #1120742
11/24/11 10:54 PM
11/24/11 10:54 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
OK, I see my mistake in reading the subject/question and responding to the OP (my apologies).
Re: car won't warm up,no heater? [Re: HoosierGTX] #1120743
11/24/11 11:25 PM
11/24/11 11:25 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
After it has run for awhile .. is the top of the rad hot? ..It should be. IF NOT .. then there is a blend-door issue in the heater uNder the dash.
Re: car won't warm up,no heater? [Re: dOoC] #1120744
11/25/11 01:56 AM
11/25/11 01:56 AM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
My '88 Gran Fury police car barely gets to the 1/4 mark and has heat. It never passes the 1/4 mark even on the hottest Florida days. Like others have said, feel the rad and rad hoses. I agree it is probably a heater core or blend door problem.
Facts are stubborn things.
Re: car won't warm up,no heater? [Re: larrymopar360] #1120745
11/25/11 08:41 AM
11/25/11 08:41 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Check the valve for the heater also.Those had vacuum problems and especially the control head in the dash.I replaced a bunch back when they were daily drivers.Check the heater hoses.Both should be hot.GMs were great for no heat with the crappy DexCool plugging the heater core.Rocky
Chrysler Firepower
Re: car won't warm up,no heater? [Re: HoosierGTX] #1120746
11/25/11 08:52 AM
11/25/11 08:52 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Switch the heater hoses at the waterpump OR firewall.
There's usually always an inlet and outlet connection in a heatercore.
If connected wrong it will trap air in the heatercore and you'll barely feel any heat in the car.
Switch the hoses around to the correct factory position and the air will be expelled from the heatercore, making it able to fill up completely with coolant and give off heat again.
Someone must have connected them wrong in the past.
Re: car won't warm up,no heater? [Re: BigBlockMopar] #1120747
11/25/11 12:36 PM
11/25/11 12:36 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Check the heater hoses, if they are both hot there is a problem under the dash. If one is hot, your core is plugged. If it's plugged flush it with a garden hose from the return (cold) side with the feed (hot) side removed from the engine.
Re: car won't warm up,no heater? [Re: justinp61] #1120748
11/25/11 04:32 PM
11/25/11 04:32 PM
Seymour,IN.
Seymour,IN.
both heater hoses are hot
Re: car won't warm up,no heater? [Re: HoosierGTX] #1120749
11/25/11 09:17 PM
11/25/11 09:17 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
You have a blend-air-door problem ... pick up a M-body FSM at the 'brary.
Re: car won't warm up,no heater? [Re: dOoC] #1120750
11/26/11 09:20 AM
11/26/11 09:20 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If both are hot Id say its a vacuum problem.The hoses usually break and loose vacuum to the control head.That or the head itself.Not a real hard system to fix.Rocky
Chrysler Firepower
Re: car won't warm up,no heater? [Re: therocks] #1120751
11/26/11 10:53 AM
11/26/11 10:53 AM
Seymour,IN.
Seymour,IN.
I'm into the vacuum hoses now,lots of dry rotted hoses,I think I'm getting close!
Re: car won't warm up,no heater? [Re: HoosierGTX] #1120752
11/26/11 09:21 PM
11/26/11 09:21 PM
Seymour,IN.
Seymour,IN.
we have heat!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: car won't warm up,no heater? [Re: HoosierGTX] #1120753
11/26/11 09:29 PM
11/26/11 09:29 PM
was it the vac mini hoses
Re: car won't warm up,no heater? [Re: RapidRobert] #1120754
11/26/11 11:05 PM
11/26/11 11:05 PM
Seymour,IN.
Seymour,IN.
yes it was the vacuum hoses under the dash,dry rotted.Didn't cost much to fix,just a little time consuming!
