Hemi Rocker Arm Deflection
#1120649
11/24/11 04:59 PM
11/24/11 04:59 PM
Posts: 290 Manitoba, Canada
liteweight
Manitoba, Canada
Hey Guys It's been awhile since I last posted here. I've been on different Cummins forums playing with making big torque numbers for my "tow vehicle". I'm starting to fit parts in my 500" Hemi that's going into the LO Dart. The reason of my post is I am getting what I think is alot of rocker arm deflection on my DLI roller rockers, around .035" at full lift @ 600 lbs. Anyone ever measure their stuff to see how much lift their lossing because of deflection????? I know guys run stock rockers on roller cams up to about .750" reliably,but, what kind of deflection are they getting??? What about valve timing??? With rocker deflection your valve timing will be retarded, even tho you did it bang on @the cam. I'm even getting .007" pushrod deflection (Crowers) Is Stage V rockers any better than the DLI or DC stuff? Sorry for the long post. Input greatly appreciated Thanx liteweight
68 Hurst LO Hemi Dart
70 hemicuda 4 spd. R code owned since 76
70 GTX 4 spd. 21,000 orig. miles
55 Ford F100 chopped,slammed,bagged & supercharged
96 Ram 2500 4X4 Twin turbo'd Cummins 550hp 1200 ft. lbs tow vehicle
Re: Hemi Rocker Arm Deflection
[Re: quickd100]
#1120652
11/24/11 08:39 PM
11/24/11 08:39 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
How are you measuring in a running environment? I have run those DLI stainless rockers and dont think its a problem. I was running 800 lbs open pressure too. Id say it's worth zero to very little power, unless its making 1400 hp or something like that. I just dont see those rocker flexing that much. Id say its in the push rods... They are so long. I cant recall how long my custom Manton's were but they look like a ram rod from a muzzle loader.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#1120659
11/25/11 01:44 PM
11/25/11 01:44 PM
liteweight
Manitoba, Canada
I'm measuring in a static environment. I would think it'll only get worse as RPM's increase. I have broken down the deflextion between pushrods & rockers. This is real world numbers, as measured: total deflection- .042" deflection, pushrod deflection- .010" @ valve (approx.) rocker deflection = .032"
I am running alot less spring pressure than you @ 600 on nose. I don't know how you can say it's not an issue. Loss of valve lift is loss of valve lift, whether it's a 400hp pooch or a 1400hp ball breaker. It's all relative, & more prominent on the higher HP stuff.
liteweight
[Re: Cab_Burge]
#1120661
11/25/11 02:01 PM
11/25/11 02:01 PM
liteweight
Manitoba, Canada
What size pushrod diameter and wall thickness are you using? What srping pressures? Those long puppys do deflect a lot, like most women will tell you, stiffer is better on some things Especially pusrods I used a set of Manton 7/16 thick .167 wall thickness single tapered pushrods on my 527 Indy 440-1 headed motor. PM me if you want some,I'm a Manton and Smith Bros. dealers, I give Mopar members a better deal than you can get when you buy direct, unless your W.D for them
Hey Cab Burge Since this is a fresh build, I am looking at a new set of pushrods anyway. The pushrods i was using for mock up were just something I had under my bench, but they were Crowers. Now that I know "average" pushrods won't cut it, I've been looking at the tapered 7/16" tapered Mantons for sure. When I get the lengths I need, I'll get back to you. I'm needing a good set of adjusters too.
Any clearance issues with 7/16" in the block or head??
liteweight
[Re: Performance Only]
#1120662
11/25/11 02:07 PM
11/25/11 02:07 PM
liteweight
Manitoba, Canada
how are you measuring pushrod deflection?
At the pushrod with test springs vs. installed springs. on the nose of lobe.
liteweight
Re: Hemi Rocker Arm Deflection *DELETED*
[Re: liteweight]
#1120663
11/25/11 03:16 PM
11/25/11 03:16 PM
Posts: 4,209 New York
polyspheric
New York
Post deleted by polyspheric
Boffin Emeritus
[Re: liteweight]
#1120664
11/25/11 04:38 PM
11/25/11 04:38 PM
Posts: 43,237 Bend,OR USA
Cab_Burge
liteweight
That is one of the things that must be checked, it may or may not be a problem. It depends on block and head castings, lifter cup hieght and many other things that we can't control Back in 1968 or 1969 Don Purdome(SP?) was one of the first racers to use and let it be known thhat the D&D tapered pushrods help his top fueler dragster 426 Hemi motor increase the useable RPM range by almost a thousand RPM by changing just the pushrods and tune up in the motor do to the increase in engine RPM caused by the stiffer pushrods revving higher BTW, be very caeful on letting the pushrods rub on anything, those tapered pushrods are not cheap and they will die young if the cups don't get any oil due to being held up and not releasing from the adjsuter to let oil into the cup Don't ask me how I know I bought three exhaust pushrods due to this I now make sure they spin easy and do drop down to allow oil into the cups, no rubbing ,even on the head gakets now, for me
[Re: polyspheric]
#1120665
11/25/11 05:04 PM
11/25/11 05:04 PM
liteweight
Manitoba, Canada
True, but only when the spring load reaches a critical level - it won't delay the opening ramp. Unfortunately, the deflection is fairly stable in time units but the valve train is obviously working at engine speed. This means that the deflection will occur earlier relative to the CL as RPM goes up. The deflection also unloads at some point, and adds the missing valve motion at a time the spring didn't anticipate. There is a "crack-the-whip" effect when this happens that unsettles all the VT pieces and it's scary to watch on a SpinTron. If actual air gaps occur (the parts are completely separated) something will break. Some cam manufacturers factor in compliance (i.e., some lobe motion being used up in compressing or bending some parts above the camshaft CL, including the cam itself, pushrod, rocker, rocker stand, etc.) when designing ramps and accel data, but IDK which ones or how to tell.
Well put polyspheric!!!! that is something I didn't think of, is the "unwinding" of forces that will occur on the close side of the ramp. very hard on parts, probably more so than on the open side of the ramp. Since the valve timing events change expodentially (sp) with valve lift all we can do is try & keep the valve train deflection to an acceptable minimum. This is exactly why I am looking at Stage V rockers. BUT, I don't want to buy a set until I know the deflection will be minimal compared to the DLI's etc. I am sure he will have figures on this. I have been trying to contact them for a while, but so far no luck. So nobody using Stage V's out there???
liteweight
[Re: Big Wedge]
#1120667
11/26/11 12:09 PM
11/26/11 12:09 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
Hi Daryl ! While the DLI rockers were the answer back in the day and the finest there was , The Barton units will do away with all of the problems you are experiencing . They are pricy but would sure seem to be the answer. Not the answer you were looking for , but surely something to be considered . chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: chryco]
#1120668
11/26/11 11:39 PM
11/26/11 11:39 PM
liteweight
Manitoba, Canada
Hey Rob I know the Jesel ,T&D's are the best out there for many reasons, but dude, I just can't justify $5k for the application I'm going to use this motor for. I want to drive the Dart this year, & I have 2 more hemi's I need to finish. Plain & simple it's about the $$$$. It just don't go as far as it used to. Did a bunch of measuring & comparisons today between stock, Indy & DLI. Not surprisingly, the stocks flexed the most, but the Indy's were not far behind. The DLI's had the least amount of deflection. What did surprise me was the amount of deflection that is occuring with less than .250" of valve lift. It is definatly affecting the valve timing in relation to the piston. Valves are opening later, your not getting the valve lift you might think your getting, & the valves are closing earlier. It's not 1 or 2 degrees, or .005 - .010" either. With the numbers I'm seeing on my motor it has me thinking if I purchase a different set of rockers, I'll order them with more ratio, just to make up for the loss of lift from deflection. As far as timing, I think I'm going to start checking at the valve with the intended to use springs, instead of degreeing it at the lifter. I'll post some measured numbers later
AND, Still waiting for some input from Stage V users . liteweight
